Re: Recording guitars with Radial J48 into Fast Track Solo
THanks, this is good advice. Seemed so simple to me to begin with.... I wasn't happy with the sound plugged directly into the Avid. Very woolly and unnatural... so I figured get a good quality active DI say the J48 or the new Neve ...the J48 made a difference but the signal's just too hot. Don't want to roll off the guitar volume as trying to capture the natural sound of the guitar with volume pot dimed. I play and record rock and usually mic my Marshall JCM 800 and Engl amps. Here's my last recording, was mixed by Mike Fraser ... and yes I micd up my guitar cabs with a 57 straight into the Avid Fast Track Solo lol https://soundcloud.com/nick-miller-2...-universe-full Right now I don't have my amps (they're in Australia) .... so doing my best to capture guitar parts as high quality and close to original guitar sound as possible. I thought the J48 would do the trick but looks like a better interface is the way to go. Here's two clips (had to convert to mp3) - one is direct into the Solo, and one with the J48. You can hear the clipping on the heavier chords. To me , it's not a volume difference, the tone with the J48 is improved IMO. Just the clipping on the heavy chords. But as our friend posted earlier, if 15db pad is needed and signal's still too hot then something aint right somewhere. http://k003.kiwi6.com/hotlink/hhruc3..._pro_tools.mp3 http://k003.kiwi6.com/hotlink/pzw0nb...ial_J48-01.mp3 Gah this seems like it should be so simple lol. Guitar into pro tools, best sound and natural and uncolored as possible. |
Elnico, you may have said so earlier but I'm still unclear. Have you tried engaging the pad on the J48, and if so are you satisfied with the tone (versus running guitar through the J48 with pad disengaged)?
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
But I want to get this right the first time, don't want to spend hours recording then realize the sound's going to be really hard to mix into something useable because I've used the wrong tool |
I hope you are monitoring this though a guitar sim plugin. I'm hearing a lot of discussion about "best sound" and that is not always obvious to judge what that means with a dry signal (well you OK you probably don't want lots of hum).
If you are not using one, go grab a copy of Positive Grid Bias Deskstop. And try tracking with and reampng with that. And then compare DI inputs once you have a wet tone you like. |
#16
If one uses a plugin or amp sim as the reference, that could completely throw one off due to the plugins' EQ and coloring of the sound. |
#17
You really want some way to get a wet signal to help you judge the dry signal. If you don't have an amp with you then find a sim plugin. Whether you use that all the time to track with or not us up to you, but I could not imagine trying to track/monitor dry... talk about being "thrown off". |
#18
Just realised I have an iRig HD.... apparently can plug straight into mac and record to PT up to 96Khz.... and is similar to the apogee jam... and has a gain control This could be all I might have needed all along. Just need the USB cable for it to plug into the Mac which I left in Australia |
#19
OK cool, we are all on the same page.
I would try out the iRig HD, and if that does not work look at a higher end interface and/or attenuator. Picking up an attenuator or two may not be a bad idea, they are always handy to have in the toolkit, and they are small since you are traveling. |
Fast Track Solo/Duo And PT 11 | GTBannah | FireWire & USB Audio Interfaces (Mac) | 10 | 01-16-2015 08:26 PM |
Fast Track Solo | RRIVERA2012 | Pro Tools Express on Windows | 3 | 06-24-2014 07:26 AM |
UA pre amp with fast track solo | SidBarone | Third Party Interfaces | 2 | 04-22-2014 11:29 PM |
PT express/Fast Track Solo | Clef_de_fa | Pro Tools Express on Windows | 1 | 03-24-2014 05:55 AM |
External Noise when recording with Fast Track Solo and Garageband on IPad 6.1.3 | The Librarian | Getting Started | 0 | 03-20-2014 12:36 AM |
