Old 07-09-2003, 02:51 PM
Redbeard Redbeard is offline
Default Level meter on Multichannel Master Fader
Do the level meters on a multichannel (5.1) master fader always follow the L,C,R,Ls,Rs,LFE layout even when the channel layout is set differently? It appears to be so in my case where the channels are L,R,Ls,Rs,C,LFE layout but the meters on the channel in edit window are L,C,R,Ls,Rs,LFE.
Old 07-10-2003, 02:02 AM
poldo poldo is offline
Default Re: Level meter on Multichannel Master Fader
Hi Redbeard,
for this problem I suggest you have to check in the setup menu, I/O setup..., and take a look wich way the DEFAUL PATH ORDER (bottom left) popup menu is actually routing...
I think you must enable the DTS/Pro Control Monitoring...
Hope this helps
AJP
We always keep on trying
Old 07-10-2003, 08:57 AM
I did set this to DTS/Pro Control. Internal meters on channel still do not match external meters (192 I/O) and outputs.
Old 07-11-2003, 03:50 PM
bump.
Does anyone know if the meters on the channel in the edit window are fixed as L,C,R,Ls,Rs,LFE?
Old 07-24-2003, 05:34 AM
Message to Redbeard:
after a while, I had time to go and check out Pro Tools HD user guide.
I thik the answer to your question is page 436 and, bad news, the meters will always display LCRLsRsLFE even if you are working SMPTE/ITU or DTS
peace
AJP
HTML code is On
Master Level Meter Numbers agrey80 Tips & Tricks 1 09-08-2010 05:31 PM
Master fader and meter readings jasonthurley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-24-2010 09:48 PM
viewing numerican master fader meter? CrAkD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-15-2008 05:45 PM
Master fader level vs headroom -help please cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 09-18-2006 10:18 PM
Master Fader Level TERRANCE Pro Tools M-Powered (Win) 2 06-01-2005 01:08 PM
