Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2018
Old 08-16-2018, 04:29 PM
nsaggio nsaggio is offline
Default Low Recording Input In ProTools
So I did some vocal tuning for the first time using Melodyne Assistant. I decided to print the tuned vocal to a new track to save on CPU power and as I did it, I noticed that the recording level of the new track was significantly lower than the original recorded vocal track. I had to boost the tuned vocal track by 7.2dB to get it back to the same level as the untuned vocal track. Any idea why this is?
Old 08-16-2018, 06:27 PM
Default Re: Low Recording Input In ProTools
Impossible to know without knowing every step of your process. Here is my method(apologies if Assistant doesn't work the same as Editor):
1-Melodyne in the first insert slot(so it analyzes unprocessed audio)
2-play/transfer and edit with Melodyne
3-once finished with Melodyne, right-click on the Melodyne plugin and choose COMMIT UP TO THIS INSERT
4-in the commit window where it asks what to do with the original track, I select Do Nothing
5-after the commit function creates the new track, I add a new playlist to the original(source) track and copy/paste the tuned audio back onto the original track.
6-if I am sure I am done, I'll delete the Melodyne plugin. If not, I drag the plugin onto the commit track and make that inactive(in case I need to revisit tuning).
This always delivers tuned audio at the same level as the source audio.
Old 08-16-2018, 06:39 PM
simonjewel's Avatar
simonjewel simonjewel is offline
FWIW totally agree and with the same results
Mac Pro 2x2.8 ghz Intel Zeon, 20 gig ram, Yosemite 10.10.5, Pro Tools 10,11,12.7.1, Logic Pro X 10.2, UA Apollo 16 quad, UA Octo Pcies, Dangerous Music 2 Bus, Antelope Audio Satori, Lynx Studio Hilo, Neve 542, Neve 511, API 505 DI, Bettermaker CV502. Avid Artist Mix, Avid Artist Control, Softube Console 1 mk11.
Protools 12 - Input Audio Window Keeps on opening Protools Cache soundman1234 Windows 0 08-25-2016 11:27 AM
Issue Recording Vocals PT12/MBox Pro 3 Input 03 (rear panel) - Works with input 01 lnc77 Pro Tools 12 6 03-28-2016 01:18 AM
Recording 96 Mic Input with HD3? pmueller VENUE Live Sound Systems 3 11-05-2010 08:02 AM
recording input from external sequencer into protools...? hoodmusik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-25-2010 05:09 PM
iI get no recording,like there's no input(M Box)! profeta956 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-30-2006 06:07 PM
