Old 11-07-2015, 02:44 PM
MindDead's Avatar
MindDead MindDead is offline
Default Net work Device Browser(greyed out) & S3 I/O!
Im trying to use the i/o on the s3, everything non i/o seems to work perfect. Following the directions in the s3 manual it asks you to open the audio/midi app and click on windows,from the top drop down menu and then select "Network Device Browser", but mines greyed out.
WHY?
How do I use the i/o on my s3?
Old 11-08-2015, 07:27 AM
ha2dorff ha2dorff is offline
Default Re: Net work Device Browser(greyed out) & S3 I/O!
Did you start S3 first, and then your Mac?
Do Eucon recognize the S3?
You should be able to see and select S3 from the Network Device Browser.
Old 11-08-2015, 10:02 AM
MindDead's Avatar
did all of what you mentioned. EUCON see it and i use it everyday.
Would it matter if I use an hf i/o as well? I should't right?
Old 11-08-2015, 11:38 AM
Sorry, I don't know...
Maybe you could try Avid support - they use to respond fast
Old 10-10-2018, 12:08 PM
Dizzi45Z Dizzi45Z is offline
Did you figure this out? I am having the same issue. The S3 works as intended as a controller, but Network Device browser is greyed out.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 10-17-2018, 12:55 AM
LukeHoward LukeHoward is offline
Is the S3 directly connected, and does your Mac support AVB? (Thunderbolt equipped Macs do, but not all Ethernet adapters do.)
If your S3 is connected to a hub you'll need it to also support AVB.
https://lukehoward.com/
Old 10-17-2018, 07:51 AM
Thank you for posting. That is my problem. I'm on a 2012 Mac Pro.
160 GB RAM
macOS 11.7.4
Remove a Greyed-Out Device in Midi Setup? Reesho 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-14-2016 12:58 PM
Midi won't work unless I have a USB device bryced87 macOS 18 12-13-2013 06:26 AM
Usb Device Doesn't work gonzogtrman macOS 0 06-24-2011 08:46 PM
sorting order of files in work space browser Lowder macOS 8 05-07-2011 02:04 PM
Digibase browser greyed out rgarstin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-10-2010 08:59 PM
