Old 02-25-2014, 12:37 AM
gub gub is offline
Default Protools rewire issue
I am running Pro tools 10.3.8(Maverick) with Reason (re-wired). Everthing in the past has been working well.
However, I went to instruments in the PT the other day and Reason had disappeared…gone. Unable to link the two anymore.
I think it may have something to do installing software to run my new Novation 25sl MKII. Novation gave me some Auto mapping software so I can run PT, Reason and Ableton.
I have a feeling this may have screwed up the ability for Rewire to link PT and reason. Additionally, when I open Abelton live i receive this message (ReWire requires OpenTransport to be installed on MacOS), not sure if that is related.
you advice on how to fix please?
Thank you
Gub
Old 02-25-2014, 10:41 AM
nicklusk nicklusk is offline
Default Re: Protools rewire issue
This same exact thing happened to me except I'm using protools 11 and Reason ReWire, but it can no longer find it. I suspect that it may have to do with a waves rewire file that Reason is somehow mistaking for it's own? Do you own Waves Tune plugins? Or have you installed another plugin that has Rewire recently?
Old 03-02-2014, 09:52 PM
gub gub is offline
No i havent got Wave tune...I'll have a look at it.
I have Reason that runs rewire (well used to), but I have recently loaded Ableton Live that came with my MkII.
I think it may have to do with the Automap software that I now run with the MkII. I found a solution on line.....'remove Digirewire plug from Automap's Plugin Manager'.......but do you think I can find this pluggin in the Automap manager. Noooo
Old 03-07-2014, 10:59 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
I think it's an issue when upgrading the OS to 10.9.1 versus 10.9.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 03-08-2014, 05:34 AM
And PT10 any version is not supported on Mavericks.
Jack
QAPLA!
Old 03-08-2014, 12:25 PM
2224 2224 is offline
Not supported should not mean not working.
JAMAICAN I IS
2008 2009 and 2010 Mac Pro 8 core with
64 GIG memory with 9 terabyte of hard drive space
blue ray player
HDX 1, 2 16X16 interfaces
sync I/O.
Old 03-08-2014, 02:29 PM
No; not supported means it may or may not work and it's up to you to figure out why and Avid won't help with it.
Jack
QAPLA!
Old 03-08-2014, 11:22 PM
i am not asking AVID for help I am asking the users on this forum. and I don't understand why everything else work but rewire, don't make no sense
JAMAICAN I IS
blue ray player
sync I/O.
Old 03-09-2014, 05:43 AM
Rewire may not be working because of being used in conjunction with PT10 on Mavericks for which PT10 was not approved. One of those things where if one link of the chain is faulty the rest may not hold together.
Jack
QAPLA!
Old 03-10-2014, 03:11 AM
Stompinmsc Stompinmsc is offline
I'm on 10.8.5 OS and upgraded to 10.3.8 PT and PT crashes EVERYTIME now when it hits the Digirewire.dpm scan. I've tried EVERYTHING. I cannot get PT to load with this plugin. if I pull it out everything is fine. I need it to work with Source connect SeRewire. Can anyone help?
ReWire to ProTools Issue nickthedangerous 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-10-2009 05:01 PM
Protools 6.4 Rewire issue with Reason 4 on WinXP Darkus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-23-2008 09:49 AM
rewire issue measure11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-12-2007 02:57 AM
rewire issue measure11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-11-2007 07:15 PM
ReWire Issue h77mack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-13-2007 09:03 AM
