Old 07-21-2006, 11:31 AM
snowjiber snowjiber is offline
Default AM2
Does anyone know if the new socket AM2 processors are compatible with Pro Tools? If so, how do they perform compared to socket 939?
Old 07-21-2006, 11:51 AM
LIMiT LIMiT is offline
Default Re: AM2
Hello..
yes, they are compatible. There is really no performance upgrade as far as the new pin design. They are to conform to the new MB's which now support (and make use of) DDR2-800 memory, which is where the upgrade is felt (kinda- I'd say, 20% performance increase).
My setup:
M2N32-SLI deluxe / AM2 4800+ X2 / 2 Gb OCZ DDR2-800 / Fire-Gl X3 / WD Raptor 74G X2
Runs like a dream..
Cheers,
-LIMiT
LIMiT
Old 07-25-2006, 11:45 PM
Runs with Scissors Runs with Scissors is offline
Default Re: AM2
Dude I just bought an AM2 and I've been fighting with it for days to get it to work with my Didi001 OR my AudioMediaIII card. I don't know if it works with PTLE 7.0, but this board definitely WON'T run Pro Tools 6.4, 6.1.1 or 6.1
AMD 64 3500
ASUS M2NPV-VM (what, do they drop a golf ball on the keyboard to get their part #'s?)
I've tried 3 sticks of PC 5200 DDR2 RAM (I believe it's 5200, 667Mhz anyway)
Onboard everything except for the onboard video disabled.
Windows XP Pro with a fresh install.
Tried it for 2 days straight in every which way, always ending with the blue screen of death. Maybe memory timing can be changed to get it to work, but I get the feeling it has something to do with the way pro tools wants to use the PCI bus...wavedriver will allow windows media player to let the digi001's interface control the pc sound output ...but here's the funny thing...the digi001 hardware checks out(per digitest)...it's Pro Tools LE 6.4 that the board can't run.
So if you're going to go AM2, I hope you're using ptle7.0, and even then I can't say that that will work. I have yet to hear of ANY PTLE system running AM2. After I tried, I looked for others who had...with no luck.
Old 01-21-2007, 10:59 AM
SeanDerMan SeanDerMan is offline
Default Re: AM2
Hi LIMit,
Can you give me your exact specs as I am planning to build a system based on the AM2 and the M2N32 Sli mobo with the 002R. Also any DaveC or DVerb test results would b much appreciated. Thanks.
i7 920, Asus P6T Deluxe V2, Win 7 64bit Ultimate, Asus NVidia 8400 GS x2, UAD-1, Digi 003R Factory with PTLE 8.03, RME Multiface, Cubase 5 32bit.
