#41
Re: Anyone figure out how to play system sounds through HD Omni?
and make sure that your system is set to use the optical out of your system sounds card... make it 2 channel SPDIF instead of ADAT.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI 7,1 MacPro, 3.2GHz 16-core, OSX 10.15 S6 M40 48-5, panners, MPM,Dolby Atmos RMU AJA Kona LHi, Sync HD www.ToolshedAudioPost.com www.TheToolshedStudio.com Certified for Dolby Atmos Home Entertainment |
#42
Reviving this thread. I've had this working but now it's randomly stopped playing through the Omni. The setup is what it should be and it was working for a brief second this morning but then I started PT and it stopped. As it's running through the digi in and the mixer is passing sound through it doesn't matter if PT is running or not.
Anyone had this problem? I'm on OSX 12.10.6, PT 2018.4,2012 mac mini. |
#43
We really cannot guess exactly what you are doing, are you taking the TOSLINK digital audio output from the mac mini into the Omni? Or what things like “is what it should be” actually means. Or what you exactly mean by “digi in”. What does the Mac’s Audio MIDI setup show? What exactly does the Omni mixer settings show? What troubleshooting steps have you tried? My first would be to power cycle everything, next to plug the TOSLINK cables into a portable DAC or similar device and see if it is working. Enough TOSLINK problems get caused by loose optical cables, or if you swapped cables by things like dust caps jammed into the socket. Sent from my iPhone using Tapatalk |
#44
My question is if anyone's had the adat input randomly stopped working? Best J |
#45
S/PDIF (and AES3) is 2 channels whether by optical cable or copper Your OMNI needs to be set for the optical in to be expecting S/PDIF if you are feeding from the Mac optical out -- which only does S/PDIF (not ADAT)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
#46
I think you meant TOSLINK S/PDIF In. It is provably a good bet that if the Omni optical input was randomly not working for many people you would be seeing posts complaining about it on DUC. You also will not get many answers to a specific question tacked onto the end of a long thread, few people here will wade through all the thread to get what is going on. Is this working now or not? If not I would go back to my earlier advice and test the output with a TOSLINK S/PDIF input DAC/headphone amplifier etc. If it appears intermittent I would suspect and replace the optical cable. As silly as it seems I have been burnt several times by faulty/damaged TOSLINK cables or debris in the optical ports (dust caps, part of the port door mechanism etc.). Sent from my iPhone using Tapatalk |
#47
I do this with my Icon desk. I even have my computers analog outputs wired into my patchbays in the event I need to record whatever sounds the computer is playing.
15 years as PTHD User, Protools 2018 Ultimate, 24 Channel iCon D-Command, Avid Omni, Lynx Aurora 16, (2) BLA Modified 192 I/O’s, DigiPre, Way Too Many Outboard Compressors/EQ’s/ETC, where did all my money go???? Last edited by Samanthas Dream; 05-10-2018 at 06:23 PM. |
System sounds don't play thru Mbox2 Pro in W7 Pro w/ PT 8.0.5 le | scott_nikki1216 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-28-2011 02:11 PM |
Pro TOols playback is OK, system sounds and other sounds won't play | bimple | Windows | 1 | 08-24-2011 05:14 PM |
Did Anybody Ever Figure out How to Get Their Mac to Play out of the 003 Console? | fooloof | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-18-2009 07:09 PM |
I cant figure out why it wont play | Mark Madness | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-26-2009 05:50 AM |
can't play XP system sounds or iTunes thru Mbox | Bassman3141 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-28-2005 04:06 PM |
