Old 10-19-2017, 02:29 PM
bitconductor bitconductor is offline
Default Latency recording stems
I'm noticing approximately a 980 sample lag in the stereo files I'm recording in a session. I've got delay compensation on, and I'm not seeing any numbers in red in the delay compensation panels under the tracks in the mix window.
Hardware buffer size is set to the max, 1024 samples.
I've trashed the prefs.
The files are bus stems from a mix. 48k, 24-bit.
If I record a stereo file in a new session with no plug-ins, recording a track from audio playing on another track (either directly from a send or via a bus) there's no latency at all.
Has anyone got any ideas about this? It's a pain as I'm having to trim the files before delivering them.
Thanks.
MacBook Pro (Retina, 15-inch, Mid 2015)
Processor 2.8 Ghz Intel Core i7
Memory 16 GB 1600 MHz DDR3
Graphics Intel Iris Pro 1536 MB
Mac OS Sierra 10.12.2
Pro Tools 12.7.1
Blackmagic Ultrastudio Mini Monitor (Thunderbolt 2)
Avid Artist Mix (Thunderbolt 2 > Ethernet cable)
Nugen Loudness
iZotope RX6
Old 10-19-2017, 03:43 PM
john1192 john1192 is offline
Default Re: Latency recording stems
Could there be plugins on the bus stems .. not sure exactly how you are routing to your bus stems .. can you be more specific please !!
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 10-25-2017, 06:39 AM
Thanks - I'm using a lot of plug-ins both on audio tracks and on aux busses. The stems get recorded from via their respective mix busses to further 'thru' busses (that have the same limiters as on the master output busses), then to audio tracks which record the stems themselves. The audio tracks that record the stems are free of any plug-ins. Hope this is understandable.
I was under the impression delay compensation took care of all this!
Old 10-25-2017, 11:20 AM
Drew Mazurek's Avatar
Master Faders' Inserts are not compensated for by ADC FYI. Always been this way.
In case it applies here. I haven't read everything in detail, just throwing this out there as a reminder.
www.drewmazurek.com
Old 10-25-2017, 06:47 PM
mixboy bob mixboy bob is offline
This is probably your fix. Hope it helps!
https://www.youtube.com/watch?v=xRIxvpdZ5Rs
Rob Burrell
aka mixboy
http://www.robburrell.com
PTHD Ultimate 2019.12/2018 Mac Mini 3.2ghz 6-core i7/32GB RAM/Aja T-Tap/Akitio Thunder 3 Quad Mini with 4TB SSD drives/Focusrite 16Line/UAD-2 Octo PCIe in Sonnet chassis/32 Channel S1/Dock with (5) 2019 Amazon Fire HD 10 Tablets/XMON//11.1.4 Dolby Atmos Setup
Old 10-26-2017, 07:22 AM
Rob Burrell
aka mixboy
Thanks Rob, but right-clicking Auto Low Latency Off on the audio tracks that record the stems is not fixing the problem.
Old 10-26-2017, 07:23 AM
Thanks Drew, but I'm not using Master Fader tracks at all.
Recording Stems confused bryced87 Getting Started 4 11-05-2013 11:04 AM
Recording Stems Simultaneously sfreiman Post - Surround - Video 4 12-01-2010 09:38 AM
Work Around: Re-recording stems while layingback to SR Deck Karl Kalbaugh Post - Surround - Video 9 12-10-2008 01:26 PM
re-recording stems & bus latency bignick Pro Tools TDM Systems (Mac) 0 10-10-2006 08:10 PM
Recording Stems into Pro Tools filmixer Post - Surround - Video 13 08-16-2004 06:56 PM
