Am I supposed to connect the hard drive to the other FW port or directly into the Mac?
002 > Drive > Mac
The 002 doesn't pass data when it's switched off so thats why it's last in the chain. It's a fair question though? Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
![]() Quote:
002 > Mac Drive > Mac The drive does not need to be chained to the 002 if that is the question.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
This is directly from the 002 MANUAL:
■ If your computer has more than one FireWire port, connect the FireWire hard drive to one FireWire port on the computer, and connect Digi 002 or Digi 002 Rack to another FireWire port on the computer. – or – ■ If your computer has only one FireWire port, connect the FireWire hard drive directly to your computer and then connect Digi 002 or Digi 002 Rack to an available FireWire port on the drive. Connecting Other FireWire Devices to Digi 002 or Digi 002 Rack The second FireWire port on the Digi 002 or Digi 002 Rack unit is available for daisy-chain- ing FireWire devices such as digital cameras or digital video recorders. Even when it is powered off, Digi 002 or Digi 002 Rack supplies power from the computer through its FireWire ports, letting you recharge batteries in connected FireWire devices. While it is possible to connect a FireWire hard drive to an available port on Digi 002 or Digi 002 Rack, if the unit is powered off, any mounted FireWire drives will lose their data connection with the computer. This may result in hard drive errors or data loss. Check out the manual first. It's very well written, and has a TON of great information in there.
Where in the world is DJ Reggie? |
I actually put the hard drive on the USB port that way I'm on separate controllers. That way I also don't have to worry about whether the Digi hardware is powered off.
I don't think I'm trading off that much performance USB 2.0 versus firewire 400 and probably making up for it by having them on separate controllers. |
Rob,
Per the Digi site: Not Supported eSATA Hard Drives Although there have been no reported issues with eSATA drives, these have not been tested by Digidesign, and are therefore not supported. USB 2.0 Hard Drives USB hard drives are NOT recommended or supported for use as recording drives. Limited testing has shown that performance with USB drives is inferior to that of FireWire drives. However, if the USB works for you, great. If it craps out on you, you know why, and also know there isn't any support here for that.
Ah, for some reason I thought it was not recommended, not explicitly not supported.
Then again, in the software world, not supported usually means "it probably will work, but we don't want to deal with troubleshooting if it doesn't". Actually, I think using the USB port arose when I was using XP and having a hard time getting PT to work. I had read somewhere that Microsoft crippled their firewire drivers to only do 100Mbs, and putting it on the USB port seemed to make PT more stable. As a side note, is there any difference in performance doing computer > drive > 002/003 vs computer > drive computer > 002/003 (for a computer with 2 firewire ports)? |
You almost got me to say something about XP, but I won't. Happily, this is a Mac forum.
Moving on... I can't really answer the (performance) question about computer>HD>002/003. I don't know if power/information/etc would go through the HD, to the unit, and then return. I'm just barely smart enough to read the directions and follow them. Any deviation on my part is...chaos. But you might want to try it. Post your results if you do. As for the last set up HD<computer>002/003, that's fine...for a laptop, or a desktop (using external (FW 400) drives (with recommended/qualified/proper chipsets). You can also use AN internal HD (as long as it isn't your OS drive). Mac Pro's can have up to 4 internal HDs. Maybe even 5, if you don't have a 2nd optical drive installed. Bottom line: If it works for you, fantastic. If you're doing something that's not recommended or supported, that's your business. If that's the case, and if/when things don't work well, expecting something other than a few 'I told you so' and 'you should have known better', is just crazy talk. Good luck to you. *cough!* even with XP
Link Button for Firewire Ports on Digi002 Rack | mjslakeridge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-14-2014 08:04 AM |
Power Mac Digi002 rack and Digi002 with faders | jpkorell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-08-2011 11:17 AM |
Pro Tools & Digi002/Digi002 Rack/M-Box | Kavie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-09-2005 02:33 PM |
Utilizing the spdif & Lightpipe ports on a Digi002 | encry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-06-2003 09:12 AM |
Digi002 Rack shipping with Digi002 plugin pack? | Vaphoron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-22-2003 02:38 AM |
