Issues with Eleven Rack and PT 11
Hi Everyone,
I upgraded to Pro Tools 11 last week, and everything appeared to working fine. Today I went in to record a guitar track using my Eleven Rack, and experienced an issue. Normally, when I start up Pro Tools, no guitar playback from the 11R will be audible unless I arm one of the tracks where the 11R is set as the input. However, in Pro Tools 11, when I start up the program, I can still hear guitar playback even if no tracks are armed for recording. The odd thing is that at this point audio is only coming out of my left monitor, or left headphone speaker. If I do set a track to be armed for recording (one that is panned 100% right for example), I still hear the playback through the left monitor, but also hear the record armed track through the right monitor. The most annoying part of this is that when I do begin recording, I can hear playback from both Left & right, when it should be panned 100% right. If I launch PT 10 instead of 11, everything functions normally where I don't hear any Eleven Rack guitar playback unless the track is armed for recording. Anyone else experience this, or any ideas how to fix this? |
Re: Issues with Eleven Rack and PT 11
What is the playback engine set to in Pro Tools 11?
It needs to be "Eleven Rack" not say "Aggregate Audio" or anything else. Try defaulting all input, output and bus IO. Go to Setup>IO and click default on each page. Reboot the computer, try again. Try trashing prefs and try starting with a new empty session. What exact computer (hopefully not really a Core 2 Duo... but even if it is that is not necessarily the issue) , OS X and driver version? etc. etc. start at the "Help us Help You - READ THIS Before Posting!" link above on this DUC page. And Pro Tools 10 and 11 coinstalled... likely not the issue, but for other reasons hopefully you have carefully followed the coinstall instructions/requirements. |
Thanks for the reply Darryl.
The playback engine is set to Eleven Rack. I had tried defaulting the input, output and bus IO's, and had rebooted but the problem was still there. After trashing prefs, I tried again and it is now working correctly in both PT 10 & PT 11. And the system info I had on my profile was not accurate. I'm now using a Windows laptop with a Core i5 & 8GB of RAM. Thanks for the tips. Last edited by JacksonRR1; 01-02-2015 at 11:49 AM. |
So this issue has returned today, and I can't seem to fix it.
Since I last posted, I have completely uninstalled PT 10 from my system, as any plugins I use are AAX, and since I thought I had this issue taken care of, there was no need for PT 10 anymore. It worked fine for a few days, and now back to the exact same symptoms I described in the original post. Here's what I have done so far: Defaulted I/O's - no change Trashed Prefs & Rebooted - no change Tried multiple different sessions & a brand new session - no change. Uninstalled PT 11 & Uninstalled 11R Driver Installed 11R Driver Version 1.1.9 Installed PT 11.3 - no change Created a new Windows User ID - no change SiSoftware Sandra ID Host Name : LENOVO Workgroup : WORKGROUP Computer Model : Lenovo 62775AU ThinkPad Edge E431 Serial Number : PF0**** Chassis : Lenovo Notebook Mainboard : Lenovo 62775AU Serial Number : 1ZSGN****** BIOS : Lenovo HEET34WW (1.15 ) 07/02/2013 Total Memory : 7.6GB DDR3 SO-DIMM Processors Processor : Intel(R) Core(TM) i5-3230M CPU @ 2.60GHz (2C 4T 3GHz/3.2GHz, 3GHz IMC, 2x 256kB L2, 3MB L3) Socket/Slot : FC PGA988 (G2) Chipset Memory Controller : Lenovo Core (Ivy Bridge) Mobile DRAM Controller 100MHz, 2x 4GB DDR3 SO-DIMM 1.6GHz 128-bit, Integrated Graphics Memory Module(s) Memory Module : G.Skill F3-12800CL9-4GBSK 4GB DDR3 SO-DIMM PC3-12800SO DDR3-1600 (9-9-9-27 5-39-12-6) Memory Module : Hynix (Hyundai) HMT451S6AFR8A-PB 4GB DDR3 SO-DIMM PC3-12800SO DDR3-1600 (11-11-11-29 5-40-13-6) Video System Monitor/Panel : Lenovo ThinkPad Display 1366x768 (1366x768, LP140WH2-TLT1, 13.9") Video Adapter : Intel(R) HD Graphics 4000 (16CU 128SP SM5.0 350MHz/1.1GHz, 64MB DDR3 1.6GHz 128-bit, Integrated Graphics) Graphics Processor OpenCL GP Processor : Intel(R) HD Graphics 4000 (128SP 16C 350MHz/1.1GHz, 1.6GB DDR3 1.6GHz 128-bit, Integrated Graphics) Compute Shader Processor : Intel(R) HD Graphics 4000 (128SP 16C 350MHz/1.1GHz, 64MB DDR3 1.6GHz 128-bit, Integrated Graphics) Storage Devices HGST HTS725050A7E630 (500.1GB, SATA600, 2.5", 7200rpm, 32MB Cache) : 466GB (C:) (Q:) HL-DT-ST DVDRAM GU70N (SATA150, DVD+-RW, CD-RW, 512kB Cache) : N/A (D:) Logical Storage Devices SYSTEM_DRV : 1GB (NTFS) OS (C:) : 451GB (NTFS) @ HGST HTS725050A7E630 (500.1GB, SATA600, 2.5", 7200rpm, 32MB Cache) Recovery (Q:) : 14GB (NTFS) @ HGST HTS725050A7E630 (500.1GB, SATA600, 2.5", 7200rpm, 32MB Cache) Optical Drive (D:) : N/A @ HL-DT-ST DVDRAM GU70N (SATA150, DVD+-RW, CD-RW, 512kB Cache) Peripherals LPC Hub Controller 1 : Lenovo Panther Point LPC Controller Audio Device : Lenovo Panther Point High Definition Audio Controller Audio Codec : Conexant 506E Disk Controller : Lenovo Panther Point Mobile 6 port SATA AHCI Controller USB Controller 1 : Lenovo Panther Point USB xHCI Host Controller USB Controller 2 : Lenovo Panther Point USB Enhanced Host Controller #2 USB Controller 3 : Lenovo Panther Point USB Enhanced Host Controller #1 SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : WebEx Document Loader (1200x1200, Colour) Printer : Send to Microsoft OneNote 15 Driver (1200x1200, Colour) Printer : Nitro PDF Driver 8 (600x600, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Brother HL-2140 series (1200x1200) Network Services Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet) Network Adapter : Realtek PCIe GBE Family Controller (Ethernet) Wireless Adapter : Intel(R) Centrino(R) Wireless-N 2230 (802.11n (HT), AES-CCMP, 144Mbps) Power Management Battery No 1 : LGC 45N1049 49.84Wh/4.11Ah Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 |
Does the Eleven Rack show up as the playback engine and work Ok when you just play back audio though it?
if so I would try a reinstall of Pro Tools 11. If that does not fix it reinstall Windows and all the apps etc. If not I'd suspect the USB cable, USB port, driver or hardware. |
Eleven Rack does show up as the playback engine, and everything sounds fine when playing back audio. When recording it also records fine, its just that the signal from the 11R will always be coming through the left channel while recording in addition to however it is panned in PT. The actual recorded signal is panned as it should be when played back after recording.
I've already uninstalled and reinstalled PT Eleven and the driver. I can try a different USB cable though. Out of curiosity, I just uninstalled PT 11 completely along with the 11R driver, and then installed PT 10 and installed the 11R Driver 1.1.9. Everything works fine in PT10. As soon as PT starts, there is no audio coming through from the 11R unless I arm a track for recording, and it follows the panning correctly. It seems the issue is isolated to PT 11 with my environment. |
Protools HDX and Eleven Rack Issues | [email protected] | Eleven Rack | 5 | 08-06-2014 09:09 AM |
Eleven Rack Editor Issues | jerry g | Eleven Rack | 2 | 04-23-2014 11:43 AM |
Eleven Rack communication issues under OSX 10.9 | lbar11 | Eleven Rack | 25 | 01-03-2014 04:37 PM |
Eleven Rack FW 1.0.3 issues forum | TheChimp | Eleven Rack | 43 | 12-02-2012 12:19 AM |
Issues with Eleven Rack. Again. | BrandonFrisby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-29-2010 03:30 PM |
