Copying automation curves
Hey people,
I am wondering, is there a way to copy the automation curve of a track and paste/apply it to another track ? Quick exemple: let say I'm hi-filtering my bass drum plugin track using a certain arc curve. Is there a way to copy it and apply the exact same curve to another track, even if it's not for hi-filtering but another effect that will exactly follow the same curve? Instead for re-drawing again and trying to match the same exact curve. I checked all around and could not figure how to do this. But man, I'm sure there a way to achieve that... Pro Tools Le, of course. Any hints ? Thanks alot mates.
MacBook Pro - OS X 10.6 - Pro Tools LE 8 - Mbox 2 Drone / Ambient / Experimental |
Re: Copying automation curves
use copy special under edit menu, automation will be a choice. then select the track and paste special under the menu.
this may only be on 7.0 and higher not sure. |
Fantastic!! Never tried that before.
Thanks for the hint, very appreciated!!
Working with Automation Curves - Best Practice | jb_trm | Pro Tools 9 | 7 | 11-23-2010 03:44 PM |
copying automation | CD Productions | Post - Surround - Video | 2 | 10-31-2006 10:12 PM |
film eq curves, dvd eq curves | ashish | Post - Surround - Video | 3 | 02-02-2004 05:17 AM |
Copying mix automation | beech | Pro Tools TDM Systems (Mac) | 1 | 09-25-2002 07:01 AM |
Fade Files and Automation Curves | francona | Pro Tools TDM Systems (Mac) | 3 | 12-23-2001 06:09 PM |
