Old 07-09-2012, 05:22 PM
DJ FADE DJ FADE is offline
Default How Much I/O Is Possible on HD Native + How to Add More OUTPUTS
Just curious how much I/O is possible on one HD Native card? I know that there are two HD ports per card, and I also know that you can daisy chain the Avid HD I/O boxes together. Does that mean I could hook up two HD I/O directly to the card, and then daisy chain more together? Or is there a limit?
Currently I have a 16x16 and an 8x8x8, and I need more OUTS (I use a lot of hw inserts and do a lot of summing) - what is the best way for me to expand my setup? Expansion card for the 8x8x8? Another HD I/O? More converters?
Old 07-09-2012, 05:27 PM
CME CME is offline
Default
I believe HD|N allows 64 channels of I/O. There's no way to go beyond that, unless you go with a DSP system. (TDM or HDX)
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 07-09-2012, 05:28 PM
smfelton's Avatar
smfelton smfelton is offline
Default Re: How Much I/O Is Possible on HD Native + How to Add More OUTPUTS
Up to 64 channels see page 7 of the manual for details (page 11 of pdf document).
 OSX 10.11.5, PT 12.5, iConnectAudio4+, Axe FX 2 XL+, Music Man Majesty
Old 07-09-2012, 08:25 PM
nst7 nst7 is offline
Yes, 64 in, 64 out.
Old 07-09-2012, 10:00 PM
FilterDecay FilterDecay is offline
to answer your question you can get a 8io for you 8x8x8 and get 8 more.
If you need more outs I would get either a omni for 8 more or another 8x8x8 with a 8io out for 16 more.
Old 07-12-2012, 12:01 PM
cool, this is awesome. looks like i'll be picking up the d/a expansion for the 8x8x8 so i can have more outs. another question - is it possible to replace the digital card on the 8x8x8 and put ANOTHER d/a expansion card? then it would essentially be 8 in, 24 out.
i know they can only do 32 channels i/o at once, but i'm not sure if it's confined to 16in and 16out, or if you can mix and match.
Old 07-12-2012, 12:02 PM
Originally Posted by nst7 View Post
Yes, 64 in, 64 out.
so if i wanted to maximize all 64, i'd have two HD I/O plugged in to the native card directly, and two more HD I/O daisy chained to the first two? is that the right configuration?
Old 07-12-2012, 01:07 PM
Correct and I believe each HD I/O is restricted to 16 I/O.
Aaron Mulqueen - 001 HD Native
Old 07-12-2012, 02:38 PM
Yep. 16 in and 16 out per unit. 4 units=64 IO. Pay attention to which version you buy. the 16x16 is best if you want all analog IO.
Native Instruments-Kontakt 5-Abbey Road Modern Drummer-Separate Outputs to PT11 martinaston AAX Plug-ins 14 11-28-2013 11:19 PM
Does HD native or native native disable plugins when monitoring inputs? BasketCase Pro Tools HDX & HD Native Systems (Mac) 7 05-20-2013 08:48 AM
Amp outputs same level as Main outputs? DonaldR Eleven Rack 0 02-07-2013 01:50 PM
Apogee Duet outputs better sounding than Digi002R outputs? Pasz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-08-2010 02:19 AM
SSL4000 native/ Renmaxx native/ DUY everpack native!!! cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-22-2007 07:58 AM
