Old 10-21-2011, 04:26 PM
DJ FADE DJ FADE is offline
Default Do I Need Pro Tools HD?
New Pro Tools 10 announcement has me wondering if I want to do a software only upgrade (currently PT9) OR if I want to spring for a purchase of an HD Native system.
My current set up is PT9 with Lynx Aurora 16 via AES16e card. On a 2008 Mac Pro. Seems to work well for the most part. Sometimes it's a little slow. Sometimes I get error messages. Sometimes on complex mixes the system gets bogged down. But for the most part, it seems OK.
I'm doing mostly rock music. Drum kit is max inputs I ever do at about 12 at a time. I'll run hardware inserts once in a while to run out to an outboard compressor like distressor or 1176 while mixing (and SSL lives on master bus). Sometimes I can track with certain plugins, but I usually don't. They seem to add some latency.
My other issue is that I'd like to be able to be mixing more as I go. As of now, if I get deep into a mix and then have to re-record parts later the session gets way bogged down and I can't track at low buffer settings unless I disable lots of tracks/plugs.
What am I missing out on? Do I need HD Native? Would a new computer be better? Or spring for full HDX card?
Any help/advice/feedback/suggestions are appreciated!
Old 10-21-2011, 04:39 PM
drumster drumster is offline
Default Re: Do I Need Pro Tools HD?
You may see a performance increase with HD Native, but I'm not sure how well the Lynx works with it. The best reports with HD Native seem to come from those on a Westmere Mac Pro using one of the new Avid interfaces. HDX is a big investment and you'd probably have to trade in your Lynx to get one of the new IO's.
Lynx Hilo Thunderbolt
2013 Retina Macbook Pro 2.7 16 GB of RAM
PTHD 11.3.1 OSX 10.10.1
Old 10-21-2011, 05:23 PM
Yeah, if I was going to do the upgrade I'd likely sell the Lynx (and a couple other things) and get HD Native + the HD 16x16 i/o
Old 10-21-2011, 07:22 PM
You won't regret going with one of the new IO's. I unloaded my Lynx back in July and am very pleased with the HD IO. The Lynx is a great box, but the Avid is in another league.
