Old 11-26-2008, 01:35 PM
DJ FADE DJ FADE is offline
Default negative bars in session
for some reason, one of my sessions starts at bar -120. how do i fix it so that it starts back at 0?
Old 11-26-2008, 04:30 PM
Whiteyguitar Whiteyguitar is offline
Default Re: negative bars in session
Highlight the track and cut (ctrl + X) then go to the bar you want to start at and paste (ctrl + V ) then save ( Ctrl + S ) you should be good to go.
Stay true to the sound,Less is best
Old 11-26-2008, 07:52 PM
its not just one track. its the entire session. does that make sense?
the minutes and seconds still start at 0. but for some reason the bar/beat is messed up an in the negatives (-120)
ive tried doing the "cut time" feature as well as "move session start" but neither of them changes the bars back to regular numbers
Old 11-26-2008, 08:37 PM
ah! i figured it out.
for anyone else who runs into this problem, use the "move song start" function in "time operations" menu. make sure you select "bars" and make sure you click the check box for "renumber" and make it "1"
hope this helps!
Old 11-27-2008, 04:44 AM
dogon dogon is offline
or just grab the red diamond in the tempo timeline and drag it.
Drop it into grid mode if you want it to snap to the bar
Old 03-11-2016, 11:47 PM
spur's Avatar
spur spur is offline
Is this no longer possible in PT12?
Cheers,
Nathan
memesounds.com
Negative Latency? swv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-03-2013 01:23 PM
deleting extra bars at the end of the session Steve@ZooWest Pro Tools TDM Systems (Mac) 4 05-29-2011 06:17 AM
Timecode and Bars:Beats in same session nucelar Post - Surround - Video 4 08-06-2009 02:42 AM
Changing Tempo - Negative Bars?? JayCRB MIDI 0 08-10-2006 09:35 PM
OT: Bars on a sequencers vs. Bars for a writer DEVIZE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-01-2003 12:35 AM
