auto follows edit ALERTER
if you mess with the "automation follows edit" setting like I do you'll appreciate this.
AFEAlerter released as a free app for Mac users. this brings a long overdue RED FLASHING LIGHT! to warn you when automation follows edit is switched off. add it to you login items and it'll put a warning in your top menu bar when AFE is switched off. 10.7 or greater... for now. NZD$0 grab it from www.maggot.co.nz |
Re: auto follows edit ALERTER
Thanks Justin!
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
BTW:
Any chance to make a little helper that disables/enables the command-alt-shift-click onto the automation type field short-cut? This disables/enables all automation lanes (incl. sends and plugins) in the entire session and you can not see it unless you dig down every single lane incl. sends. Cheers, Frank.
Genius, thanks!
my blog:Tamas Dragon |
Does it work with pro tools9?
maybe.
only tested on my own PT machine: 10.7.4 PT10.1.1 uses system events so you need to make sure "access for assistive devices" is enabled in the system prefs - universal access. justin |
the flashing red light is intermittent on my system
mac pro 1.1 osx 10.7.4 NVIDIA GeForce 7300 GT 256 MB but I still like it anyway :-`) AVID take note.... Now if we can have a lock light for VTs and PT - like the AMS machine control... cheers
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
working great after a reboot - "lovin it"
Justin and Maggot Software rock! cheers
has been updated.
as per user feedback it now flashes the entire screen in a red tint. there's no preference for it - so if you prefer it less in-yr-face then don't upgrade. www.maggot.co.nz |
Thanks Justin. Frank.
auto follows ALERTER | The Cargo Cult | macOS | 0 | 06-27-2012 02:54 AM |
Why use 'Punch Auto Preview' and not just 'Write Auto to Selection? | Moviesound | Post - Surround - Video | 23 | 03-01-2011 12:24 PM |
Machine Control and Auto-Edit Not Reliable | Chief Technician | Post - Surround - Video | 23 | 08-18-2008 05:03 PM |
Edit window "auto pace?" | stainless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-11-2006 07:14 AM |
Edit Window Auto Scroll??? | EricLiebman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-17-2000 09:22 PM |
