Old 11-19-2006, 02:15 AM
trion12 trion12 is offline
Default Can\'t record Roland GR-33 guitar synth with MBOX
I am unable to record audio out from a Roland GR-33 guitar synth to analog inputs of an Mbox without horibble crackling, static, buzzing making a track unusable.
My GR-33 works fine to an amp for live gigs and my electric guitar works fine plugged in to the Mbox for recording.
I have tried both line and instrument input settings on the Mbox to no avail.
Any thoughts?
Thanks.
Old 11-19-2006, 06:59 PM
albee1952 albee1952 is online now
Default Re: Can\'t record Roland GR-33 guitar synth with MBOX
Line in should work just fine. Have you tried different volume levels from the GR? Maybe it is set too hot? I don't know the GR at all so I will assume you are using analog outputs on quarter inch plugs and not a SPDIF out on an RCA plug. Are you using standard guitar cables? I believe you should as the GR is most likely unbalanced out. Maybe some new cables are in order?
Old 11-19-2006, 08:13 PM
Line in, standard 1/4" guitar cable and tried setting levels differently but to no avail. As I mentioned the unit works fine to my amp with the same cables. I wonder if there is some sort of mismatch between the analog outs from the Gr-33 and the analog ins of the Mbox?
Old 11-19-2006, 10:16 PM
Jerry K. Jerry K. is offline
Do you think there could be to much level internal in the GR?
Jerry Kelley
jerry@jlkstudio.com
www.jlkstudio.com
Old 11-20-2006, 12:44 AM
I doubt it as I can play it through an amp or headphones fine. My guess is some kind of electrical mismatch happening between the GR and the Mbox?
Old 11-20-2006, 07:51 AM
I can record my GR-33 and my VG-88 into my 002-R and my Mbox with no problem. Do you have the correct output selected, to go to full range? Don't know if this would matter?
Jerry Kelley
jerry@jlkstudio.com
www.jlkstudio.com
Old 11-20-2006, 11:34 AM
Not sure what you mean . . . how does one select output and what do you mean by "full range"?
I am plugging the 1/4" cables into the Mix Out jacks of the GR-33 and then directly onto the line inputs on the Mbox.
Old 11-20-2006, 01:39 PM
Aussie169 Aussie169 is offline
A friend of mine has been recording the GR-33 into an Mbox for years. (Well, as many years as the Mbox has been around).
Do you have the Mbox inputs selected to Line?
Old 11-20-2006, 07:09 PM
Yup . . .
Old 11-21-2006, 07:07 AM
You can tell the GR to whether it is going into a full range speaker (Mbox) or a guitar amp. This may not be the problem but it does affect the signal.
Jerry Kelley
jerry@jlkstudio.com
www.jlkstudio.com
record / play / MIDI edit E-Drum synth (Roland TD-15) syndicat Pro Tools 10 0 03-12-2013 01:39 PM
Mbox 2 .My Roland V synth doesnt recive midi otiv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 04-29-2006 09:52 AM
Using A Roland GR-33 Guitar Synth To Trigger MIDI jumpnblues MIDI 2 09-19-2005 10:05 PM
Roland Guitar-synth and delay ??? Xbitz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-24-2004 12:31 AM
Roland V-Synth Vegadark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-23-2003 10:52 AM
