DigiRewire Plugin Crashes Protools on start up
The DigiReWire plugin will crash Protools on bootup unless it's removed. This happened to me when I upgraded to 7.4.2 and is doing it again on PT8. Not a big deal since I don't use it but thought I would make you (Digi) aware.
When I load up Protools, it goes though everything and crashes at the moment it starts loading DigiReWire.dpm. Apple Quad G5 2.5 4GBs Ram 10.5.6 OS |
Re: DigiRewire Plugin Crashes Protools on start up
IDENTICAL problem here in Pro Tools 8. I also have the same exact computer as the original poster... (only I have 10.5 gb of ram). The thing is, I USE rewire all the time so I need to figure out how to solve this.
Any ideas?? Thanks! |
Try this:
http://thestudiofiles.com/?p=49
www.thestudiofiles.com |
Please be sure you've updated any existing versions of Celemony Melodyne to Leopard compatible versions. If you once had Melodyne but removed it, or just want a quick fix without downloading any updates go to this directory:
/Macintosh HD/Library/Application Support/Propellerhead Software/ReWire and delete any files that contain Melodyne in their filename. |
Start up Stalling on DigiRewire.dpm | robsperti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-18-2010 07:36 AM |
DigiRewire Plugin Crashes PT8 - help!! | lemieux | Pro Tools TDM Systems (Mac) | 8 | 12-19-2008 03:11 PM |
Digirewire plugin crashes 7LE on app startup | Reactor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-21-2005 09:17 AM |
Digirewire crashes Protools LE on startup | dancheung | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 03-16-2004 12:25 AM |
Digirewire crashes on startup | dancheung | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-04-2004 05:10 PM |
