Mute works intermittently
Procedure: Referencing a mix, I will un-mute and solo my ref either by clicking the Mute and Solo buttons at the same time, or the Mute followed by Solo a micro-second afterwards. I then quickly stop/start playback to hear again from a specific place. Then mute/unsolo the ref in the same fashion to get back to the "live" mix, and stop/start playback in the same fashion. I'm moving very fast using an Avid S1.
Problem: When muting the ref to switch back to the live mix and restarting playback, sometimes I will hear the (very clearly muted) ref and the live mix at the same time (double the volume!!) Stop/Start playback quickly will give me the actual playback I want to hear, but my ears/brain have been blown out and I need a moment to re-calibrate. Workflow killler. Nothing fancy, I'm working in Stereo. Other than this weirdness, the system is super stable and snappy and I never have CPU errors ... this problem stands out and has for awhile now. Not sure exactly which version of PT it started in, or if it's been here forever. Anyone else having this? Is there a bug logged? I kill Avid Link every time I install PT ... do I need to install it to log a bug?
MacMini M1 (2020) / macOS 13.6.4 / PTU 2023.12 / Avid S1 Last edited by Teej; 02-06-2024 at 01:36 AM. |
Re: Mute works intermittently
Thank you for raising the issue! |
Cool, thanks! Forgot to mention I'm using an S1. Added to sig and post. How do I check status of 04753255?
MacMini M1 (2020) / macOS 13.6.4 / PTU 2023.12 / Avid S1 |
Sure thing! Just log in to your Avid Account > My Support > Access the Support Center > My Open Cases. Can you message me along with your Avid account email address so I can check also? Thanks!
Shortcut Shift+M no longer works (mute tracks) | Louga | Pro Tools 12 | 3 | 06-30-2021 08:11 AM |
Forum Down Intermittently | Avid | General | 0 | 01-23-2019 12:54 PM |
Help (Frustrated) Play button works intermittently | jspellos | Windows | 3 | 07-08-2014 10:48 PM |
Adding insert plug-ins only works intermittently | cytokinesis | macOS | 0 | 06-24-2011 01:59 PM |
mbox, ibook, protools- sounds works intermittently | vicsclipse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-22-2006 05:36 PM |
