S/PDIF, ADAT, Word Clock - Recording At Optical IN (003R).
I've asked this before and can't make heads or tails of WHY I cannot get a signal from the DIGITAL OUT (Optical) of my SYNTH to the DIGITAL IN (Optical) of my DIGI 003R. This worked FINE with my 002R, 002 and 001.
I would just connect the cable, select S/PDIF IN L/R, RECORD and VOILA, it would work without issue. Yes, I would make sure that the HARDWARE SETUP has S/PDIF selected and OPTICAL as the clock source. This worked on every other DIGI unit. Why is this not working on my 003R? Why would anything have to be different. No I haven't utilized WORD CLOCK, but I shouldn't have to if this worked on every other Digi unit. Any suggestions?
Macbook Pro 15" (Mid 2014) 16GB RAM 512GB SSD Pro-Tools 12 2.5GHz i7 Quad Core |
Re: S/PDIF, ADAT, Word Clock - Recording At Optical IN (003R).
Go into Hardware setup(in Pro Tools) and make sure that Optical =SPDIF. It likely defaults to ADAT(8 channel) and you probably need optical SPDIF(2 channel).
Recording S/PDIF inputs w/ ADAT clock source on LT LE | somberberry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-27-2008 08:11 PM |
Clock Issue on 192 i/o Optical [ADAT] Not Optical [Encl] | Willard | Pro Tools TDM Systems (Mac) | 1 | 10-10-2007 01:23 PM |
Word Clock and SYNC on an 003r | Elecshop | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-08-2007 10:21 AM |
Has anyone got a 003r to sync via word clock? | amverdile | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-16-2007 09:44 PM |
Clock Source: Word or Optical ADAT? | RobMacki | Pro Tools TDM Systems (Mac) | 7 | 04-15-2006 06:32 AM |
