lacie 5400 w/ macbook pro 7400?
Hi all,
I am getting my first pro tools set-up with mbox2 pro and a new macbook pro, 2.53 ghz with 250 gb 7200 rpm hd. Will there be a problem, performance or otherwise if i record to a lacie ext hd of only 5400 rpm... Would appreciate greatly any advice... cheers |
Re: lacie 5400 w/ macbook pro 7400?
'Fraid so. Too slow. You're likely to get all kinds of error messages about "can't get audio fast enough." And Lacie doesn't have the best rep on the DUC, on the whole, either. Seagate and WD are the trusted brands. Make sure you get a drive in a case that has the Oxford chipset, and at least 7200 RPM. See this page for full details:
http://www.digidesign.com/index.cfm?...4&itemid=23140
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Thanks for that, it confirms all the research I've done since... I'm going for a glyph gt050q 500 gb... this should be good yeah?
cheers |
i am also looking at glyph drives for my audio
would this be good? http://www.echo4media.co.uk/Glyph-Te...-1000)/232.htm i have not spotted mention of the oxford chipset but im sure i have read that people use glyph drives...does this have it? is it quiet enough? does it meet all the requirements for pro-tools? |
Yeah, it's supposed to be one of the best. This page gives all the nitty gritty details:
http://www.glyphtech.com/products/gt050q.html You see where it says Bridging Chip: Oxford 924
what a really helpful site! i am liking these guys. think i will spring for a couple of these drives.
quick question, i am getting ready to buy one of these glyph drives. should i go for the bigger the better?
i could go for a 1TB drive but is it as good as a slightly smaller drive? obviously if i get a drive that big i will need to buy a second one that size as a back up whereas if i buy a smaller sized drive for use i could then get a 1TB as a back up... if i have the money, should i just spring for the largest drive possible? |
There seem to be mixed reports about 1TB drives. Good for some, not for others. If you do get one, partition it up into 4 250s, or 8 125s or something. That should help keep data from getting scattered too far apart, I think. As long as the seek time is as short for the 1TB as for the smaller one, it should be OK.
ah. interesting. i have opted to go for the 1tb and will partition. thanks for the advice.
right, well, the drive arrived today and i did a partition into 4.
it placed 4 drives on the desk top! this is rather a messy way. i thought it would look more like when you open the macintosh HD and inside there would be 4 drives. if i had partitioned 16 drives i would have a very full and messy looking desktop. is there any way of arranging this better? place them in a sort of folder view? i would like to view them in 'column view' for instance. so when i click on a desired partition the arrow opens out and shows me what is inside the drive etc. is this possible? i am new to mac so please answer as if i know nothing! thanks! |
LaCie d2 3TB w MacBook Pro Questions | NoiseRoom | macOS | 9 | 11-22-2013 10:31 AM |
Lacie 320 7200 fw400 with mbox pro on macbook pro | kpetrosky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-11-2010 11:15 AM |
Troubles with Macbook + LaCie + PTLE 6.9.2 | maxf | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-21-2006 08:28 PM |
Daisy Chain LaCie d2 with 002 rack, on Macbook?? | vietarmis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-11-2006 02:42 PM |
7.1.1 LE / Intel MacBook w/LaCie Firewire external | 7thheaven | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-31-2006 08:18 PM |
