Comparable Oxford Chipset?
Greetings!
I just could not pass up a deal on an Acomdata E5 series FW400 (7200rpm) HD to use with my PT's LE rig. When I asked about the bridge chipset, I was informed: "Unfortunately our E5 Firewire drives do not use the Oxford chipset. They do however use the Initio chipset, which is a comparable brand that should work perfectly fine with Pro Tools." Upon searching the Digdesign Support/Compatability area, I found this from Digi: "Check with the drive manufacturer to verify that their drive has the "Oxford 911", "Oxford 912", "Oxford 924" or comparable chipset & drive speed of 7200 rpm." My Question: Can anyone tell me if this Initio chipset is one of Digi's mentioned 'comparable' chipsets? I have not done much work with this drive yet, but it seems to operate fine (at low track counts, primarily editing, etc.). Anybody have any general comments on the E5 Drives? Sometimes 60% off is too good to pass up... at least I can put a bunch of pix and misc on 'er! Thanks in advance for your replies, Steve MacBook Pro, 2.16 GHz Intel Core Duo, OSX 10.4.9, 2GB ram, Digi002, PTLE 7.1.1cs2, MP Toolkit PS: I did install the 'patch' to PT's after inadvertently installing OSX 10.4.9, and the rig is working fine, but I want to avoid problems, or be aware of any issues...
PT's 9.0.5; Mac Mini 2.3 GHz Intel Core i5; 8GB RAM; OSX 10.7.1 Lion; OWC Mercury 100GB FW800 HDD; Digi 002 Factory+MPTK; and a nice Pearl drumset! |
Re: Comparable Oxford Chipset?
I just got the Acomdata 500 GB Mini Pal, with a four port USB bus and three FIREWIRE 400's.
It was only $150.00 and it's 7200 RPM, <9ms seek time, etc. Their website says it's "comparable" to the Oxford 911 chipset - made by Initio, like you mentioned. I figure it's worth a shot, hooking it up now, just got it... Will report back...
PT LE 7.1.1 / DIGI002 / MacBook Pro 2.16 Ghz / OSX 10.4.8 "officially supported" (although it doesn't work at all right now) / M-Audio Axiom 25 / Kensington Expert Mouse PRO / Korg DT-10 / Sony MDR-7506 / AKG C 214 / |
Hi, This may or may not be relevant but i stumbled upon this while digging for digidrive info yesterday.
I only post this as it mentions the "initio" chipset. http://www.digidesign.com/index.cfm?...4&itemid=23131 |
I would AVOID Initio chipsets at all cost. These don't work well with Pro Tools or at all when streaming audio in my experience, lots of buffer underruns and errors. But can cost less than Oxford, so people end up with Initio.
Stick to Digi's recommended Chipsets, these play well with all DAW's that I've came across: FW 400 on Oxford 911 or FW400/800 on 912 and 924 is supported on Mac: http://digidesign.com/index.cfm?lang...4&itemid=23114 |
where can i buy external drive compartible with pro tool in u.k ?????? pls i mean cheap ones , i can find them all in us but not u.k ,any idea pls ?
Owner, www.wishingdigital.com External Hard Drive & Content Creation Application Experts |
Oxford 934 chipset and FW 800 | Rojin | Storage Subsystems | 0 | 05-31-2011 01:01 AM |
Still Oxford chipset? | DannyG | Pro Tools TDM Systems (Mac) | 1 | 08-23-2007 09:12 AM |
Oxford 911 Chipset | CoolWhip | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 07-13-2006 03:09 PM |
Oxford chipset still? | DannyG | Pro Tools TDM Systems (Mac) | 1 | 02-25-2005 02:16 PM |
Oxford 911 chipset | tsampson | Pro Tools TDM Systems (Mac) | 0 | 06-18-2001 08:54 AM |
