haunted by the 6093,6086 error msgs!
it's crazy - but, i'm still getting these error messages - i've read every post, every tip, everything in the refs and manuals - talked to digi-tech support for 1 & 1/2 hrs - they couldn't figure it out -
i have a brand new (dec.04) Digi002 - PTLEv.6.4/ MAC G4 CPU/1.25GHz/OSX10.3.7/512MBRAM - it was working fine for the first month - then, it started with the error 6086,6093 msgs.. i feel like i've tried everything - even taken the mac back to the apple store just to double check it's gutts and make sure it was all in tact. i get these messages even while trying to record a single click track. could something be wrong with my video card ? it's a long shot, but i heard rumor some cards could cause buffer size errors --- peace and many thanks to anyone who could help -- |
Re: haunted by the 6093,6086 error msgs!
This may sound redundant on the 002 DUC but you gotta replace you power harness and power supply. Call Digi and they'll send a replacement repair kit overnight with instructions to make it easy.
Good Luck, RS |
i am reading all the problems discussed here on the DUC with the 002/002r power harness ---
i hope you are right - i will try anything at this point !!! thank you - gigi |
I'm pretty sure that's what it is. I had the same exact problem. You can also try reseating the power harness. Some threads mention that this sometimes can solve the problem.
RS |
i5 Quad Core system, Error Msgs 9093 9094 and 6086...any help welcomed. | word_play | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 51 | 02-26-2010 01:35 PM |
-6086 & -6093 error on 003 Rack | Clayonline | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 09-09-2009 01:29 PM |
DAE error 6086 & 6093 messages | rrolsen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-13-2008 09:02 PM |
Protools LE 7.3 crash, error 6086, 6093 | carpox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-11-2007 04:15 AM |
PT error messages tried every fix 6093, 6085; 6086 | decoy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 22 | 04-26-2005 11:39 AM |
