Old 05-24-2010, 10:46 AM
gjohung gjohung is offline
Default Profire 2626 Issue
Acquired Profire 2626
Upgrade/move from MBox Classic...
Worked A-Ok on MacBook Pro. as a mobile system.
Installed PTLE on PC Home made Quadcore running Windows XP.. everthing loaded ok. existing PTLE files opens an plays fine
But I am getting constant lock up..mouse locks up and when I try to record there was a crackle...etc.. firewire issue?? My PC set up is with dual monitor and multiple HDD etc... great PC to do final edits..
But I used to run Digi002 on this PC and it was fine...
Help...
Apple: MBP 2.53 - 4G RAM HDD 500G, iMac 27 inch 1TB
ProFire 2626, MBox Micro, PTMP 8, NIs, Strike, POD Farm, Logic 9, EJ Strat, 52 Tele RI, MB Mk 3, PRS CE22, Epi Casino, PBass, Variax, L6XTL, M13, DRRI, BM iGuitar, GR-33, KeyStation 88, Axiom 49
Old 05-24-2010, 06:04 PM
jojo99 jojo99 is offline
Default Re: Profire 2626 Issue
Try out (great if you can borrow or get a return policy set) a T.I chipset fwire card and see what happens.
Old 05-25-2010, 01:37 PM
I will try another FW card but... if it worked under Digi002 ....why is it not working under ProFire 2626
Old 05-25-2010, 05:33 PM
lifer lifer is offline
Umm.. LE doesnt work with 2626.. you need MPowered for that..
im amazed it will even launch.. unless you are trying to use a "special" driver?
Win 7 Pro 64
PT 10 HD, HD4 Accel
Jetway JNAF92-Q67
Intel 2700k 3.8ghz
16GB Crucial Ram
Old 05-26-2010, 12:45 AM
I have PTMP (ProTools) M-Powered.
I got new FW that has Texas Logo and now it works..
Old 05-26-2010, 07:33 AM
May be I am not looking deep...
PTLE on Digi002 had low latency option.. did they took it away on PTMP? I am trying to record guitar using POD farm..and I hear both unprocessed and processed guitar tone.. how can I disable direct monitoring.
ghj
Old 05-26-2010, 11:12 AM
Yeah, I personally avoid any Fwire interfaces, but if you're going to I think the T.I. chip Fwire is the one to stick with. Glad it's working for ya.
Old 05-26-2010, 02:27 PM
But on my Mac I have no issue...
Old 05-26-2010, 05:50 PM
I was ale to switch back and forth between 002 and Mbox... and LLM was avalable with 002.
Is this not the case with FP 2626..?? Running PTMP on Mac & PC. Some say it is a bug,,, some say they really took it out,
Please give in insight..
Also,
Is there a way around this.. Instrument track are OK... but XLR or line input is an isssue..
ghj
Help
Old 05-26-2010, 06:19 PM
necjamc necjamc is offline
To disable hearing both signals, go into your Profire 2626 control panel and switch to see pic.
Pic 1
Setting to software returns will bypass the direct signal in.
Is the Profire 2626 more stable than Profire Lightbridge? (PT8 or snow leopard?) tomv-k Pro Tools M-Powered (Mac) 5 03-09-2012 02:45 PM
profire 2626 paldry macOS 4 10-13-2011 03:12 AM
Wordclock Issue - Profire 2626 Siegfried Meier Pro Tools M-Powered (Mac) 24 03-10-2011 07:35 PM
Mpowered 8.1, profire 2626, Clock issue nickomatiz Pro Tools M-Powered (Mac) 2 09-23-2010 02:20 AM
Profire 2626 routing issue boabyd23 Pro Tools M-Powered (Mac) 0 05-03-2010 02:27 AM
