Old 11-01-2008, 06:13 PM
woodman01 woodman01 is offline
Default PTLE 7.1 - Audio processing is conflicting with other CPU tasks. (-9129)
Hello,
I've been checking the forum to find a solution for a problem I keep having with my desktop. When I create 2 audio tracks and add plug-in instruments (NI Guitar Rig 3 or Battery 3) I receive the following error: Audio processing is conflicting with other CPU tasks. (-9129). I have a seperate disk for audio (7200 rpm), disabled AV, disabled NIC, XP ATA drivers installed, removed almost all the plug-ins, ... but the issue remains.
I was hoping some could help me here...
I added the Sandra ouput to document my computer:
SiSoftware Sandra
System
Host Name : NEXUS
User : Woodman
Workgroup : WOODMAN
Processor
Model : Intel(R) Pentium(R) 4 CPU 3.20GHz
Speed : 3.20GHz
Cores per Processor : 1 Unit(s)
Threads per Core : 2 Unit(s)
Internal Data Cache : 16kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing
L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 lines per sector, 2 threads sharing
System
Mainboard : Intel Corporation D925XECV2
Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
System BIOS : Intel Corp. CV92510A.86A.0477.2006.0209.2000
Total Memory : 2GB DIMM DDR2
Chipset
Model : Intel 82925X/XE Host Bridge / DRAM Controller (B1 Step)
Front Side Bus Speed : 4x 200MHz (800MHz)
Memory Bus Speed : 4x 133MHz (532MHz)
Video System
Adapter : NVIDIA GeForce 6600 (128MB DDR, 300MHz/2x548MHz, PCIe 1.00 x16, PS3.0, VS3.0, 2 Heads)
Adapter : NVIDIA GeForce 6600 (128MB DDR, 300MHz/2x548MHz, PCIe 1.00 x16, PS3.0, VS3.0)
Storage Devices
ST3160827AS 160GB (SATA150, 3.5", NCQ, 8MB Cache) : 149GB (D:)
ST380817AS 80GB (SATA150, 3.5", NCQ, 8MB Cache) : 75GB (C:)
PLEXTOR DVDR PX-716A (ATA66, DVD+-RW, CD-RW, 8MB Cache) : N/A (E:)
HL-DT-ST DVD-ROM GDR8163B (ATA33, DVD+-R, CD-R, 256kB Cache) : N/A (F:)
Logical Storage Devices
Data (D:) : 149GB (NTFS) @ ST3160827AS 160GB (SATA150, 3.5", NCQ, 8MB Cache)
WoodMastah (C:) : 75GB (NTFS) @ ST380817AS 80GB (SATA150, 3.5", NCQ, 8MB Cache)
CD-ROM/DVD (E:) : N/A @ PLEXTOR DVDR PX-716A (ATA66, DVD+-RW, CD-RW, 8MB Cache)
CD-ROM/DVD (F:) : N/A @ HL-DT-ST DVD-ROM GDR8163B (ATA33, DVD+-R, CD-R, 256kB Cache)
Peripherals
LPC Hub Controller 1 : Intel 82801FB/FR (ICH6/ICH6R) LPC Interface Bridge
LPC Legacy Controller 1 : SMSC LPC v1
Audio Device : Intel 82801FB (ICH6) High Definition Audio Controller
Serial Port(s) : 1
Parallel Port(s) : 1
Disk Controller : Intel 82801FB (ICH6) Ultra ATA Storage Controller
Disk Controller : Intel 82801FR/FRW (ICH6R/ICH6RW) SATA Controller
USB Controller 1 : Intel 82801FB (ICH6) USB UHCI Controller 1
USB Controller 2 : Intel 82801FB (ICH6) USB UHCI Controller 2
USB Controller 3 : Intel 82801FB (ICH6) USB UHCI Controller 3
USB Controller 4 : Intel 82801FB (ICH6) USB UHCI Controller 4
USB Controller 5 : Intel 82801FB (ICH6) USB 2.0 EHCI Controller
FireWire/1394 Controller 1 : Intel FW322/323 IEEE1394 OHCI FireWire Controller
System SMBus Controller 1 : SMBus Dev Drv 1
Printers and Faxes
Printer : PDFCreator (4000x4000, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : Microsoft Office Document Image Writer Driver (200x200)
Printer : HP Deskjet 6500 Series (USB, Colour)
Network Services
Network Adapter : Marvell Yukon 88E8050 PCI-E ASF Gigabit Ethernet Controller - Packet Scheduler Miniport (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System(s)
Windows System : Microsoft Windows XP (2002) Professional 5.01.2600 (Service Pack 3)
Platform Compliance : x86
Thanks in advance!
Woodman
Old 11-01-2008, 07:07 PM
Default Re: PTLE 7.1 - Audio processing is conflicting with other CPU tasks. (-9129)
Does it run okay without those plugins? If so, maybe they are not up to date(either or both). Or maybe one or both need to be uninstalled and re-installed?
Old 11-03-2008, 10:58 AM
DigiTechSupt's Avatar
Which Digidesign hardware are you using? Are all your drives set to DMA mode in the Device Manager?
Avid Audio Tech Support
Support FAQ
9129 - Audio Processing is conflicting with other CPU tasks - Error help needed! Badfish00 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-07-2009 05:48 AM
Audio processing conflicting with cpu tasks...? Beyond The Pale 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 29 05-11-2006 04:31 AM
Audio Processing is Conflicting w/ Other CPU Tasks chillax69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-16-2006 08:04 AM
Audio Processing is Conflicting with other tasks vide 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-27-2001 01:18 PM
Audio processing is conflicting with other CPU tasks bersonique 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-24-2001 06:16 PM
