Compression/limiting after encoding
Is it okay to add compression/limiting and more gain after encoding LtRt. Will this ruin the encoding? i just want to beef up the stereo LtRt a bit. That way I can use a better stereo limiter and not the surround limiter.
Re: Compression/limiting after encoding
Knowing how sensitive Dolby gear is to proper alignment, I would not recommend it, though I've never tried doing anything like that myself. You could do a test by reprinting your files after the gain and compressor and then decoding them. I would think that you would have a number of phase problems along with shifting stereo imaging problems.
Rick Sanchez http://www.posthastemedia.com MacPro 2x2.66 GHz Dual Core "WoodCrest" Mac OSX 10.5.8 / 4 Gig Ram ProTools 8.0.4 Digidesign/Magma PE6NE-I upgraded 6 slot expansion chassis. (Host card in Slot 2 of MacPro) HD3 Accel BlackMagic Decklink Studio 2 (In Slot 3 of MacPro) SurCode / Dolby Media Meter 2 Izotope RX2 Advanced / Sonic NoNoise Waves Platinum 7.x / Serato PitchnTime Melodyne Studio / Altiverb XL / Speakerphone KOMPLETE 7 EQuality / Massey L2007 TC MasterX |
what about just gain?
Do it all the time. It does not affect the encode. Vaguely remember asking Ken Hunold, Dolby broadcast engineer about it a few years ago and seem to remember that he said it was O.K. but don't quote me on quoting him. I find using a L3 Multi on the LTRT beefs it up a bit and helps control peak levels a little better than trying to do that with a 5.1 compressor on your surround mix.
Eric Thompson
Eric Thompson Mixer/ Sound Designer Outside Editorial 69 mercer street [email protected] www.outsideedit.com |
Normalizing vs Compression or Limiting | barismanco123 | Tips & Tricks | 17 | 01-23-2009 11:08 AM |
6.1 Compression & Limiting | derF | Pro Tools TDM Systems (Mac) | 1 | 05-20-2004 12:34 PM |
Limiting and compression. | Garry Taylor | Pro Tools TDM Systems (Mac) | 4 | 04-26-2002 07:32 AM |
Hand Limiting or plug-in Compression? | DJ Burt | Tips & Tricks | 4 | 01-10-2002 09:42 AM |
Compression and Limiting - External DSP | choctop | Digidesign Hardware & Software | 1 | 03-28-2001 01:07 PM |
