Unable to open session from the session icon
If I double click the session icon, the pro tools starts up but the session won't open. However I can open the session from open menu in the pro tools. I used to start the session by simply double click the session icon. Do you guys know how to fix this? Thank you . |
Re: Unable to open session from the session icon
Odd. Is this happening on just one particular session or all of them?
Paul Peterson Sound Director The Old Globe San Diego, CA |
That's because the Creator Type isn't set.. this happens if the resource fork is damaged or the file is brought over from a PC or via email usually -- just open the session from the File menu (Command+O) then save it on the Mac.
Rail
Jah-d, have you tried doubleclicking the file again once PT has loaded? I have the exact same problem here, but that's probably due to a spurious -3000 error I get every time PT fires up. |
Aah.. sorry I missed that Pro Tools started.. in that case he should check if he has mnore than one version of Pro Tools installed on his system -- this can happen if there's another version on one of the drives. If he has ResEdit or Resourcerer he should check that the session type is PTS and the Creator is PTul
Rail
Thank you guys for the reply. All sessions are unable to open with double clicking the session icon. However I can open up the session with double clicking if the pro tools is on. I have only one Pro tools application in my system. I was able to open the session with double clicking the session icon before. Since a couple days ago , this problem has started.
I would search your drives for another version of DAE.. the only time this has ever happened is with more than one version residing on the drives.
Rail
This exact same problem happened to me and two other PTools users that I know.
I definately do not have another DAE anywhere on my computer. It's only started recently, and although its not exactly a life and death matter, it is curious.
Studio: Mac Pro Trash Can 2.7 Ghz, 32Gb RAM, Sonett xMac Pro Server, HDX 22.12, S6 M10 24 Fader, Rednet 5,1 and 4 Live: MBP 16" M1 Max i7 32Gb RAM, |
I've seen this problem on at least 4 G4's, including 2 of mine. Various OS's from 9.04 to Jag. Seen it on TDM rigs too.
http://www.phuturetrax.com |
Unable to Open Session | mundo66 | MIDI | 0 | 11-10-2006 08:27 AM |
Can't open session-generic grey "exec" icon | gman007 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-25-2005 10:28 AM |
Unable to Open New Session, Open Session..... | ThisBeatsWorking | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-15-2003 11:17 PM |
Help - unable to open session G4/500 HD PT5.3 | letrev | Pro Tools TDM Systems (Mac) | 4 | 05-15-2002 12:52 AM |
unable to open a session | zagreb | Digidesign Hardware & Software | 0 | 12-06-2001 08:31 AM |
