Old 06-07-2000, 12:37 AM
francisco francisco is offline
Default wave out\'s api windows standard
in a future is possible that they could be controlled more of the two-channel wave drivers i/o with the standard api of windows ?
it is possible to assign the two-channel wave drivers i/o wave api standard windows to any o/i digital of the box?
[This message has been edited by francisco (edited June 06, 2000).]
Old 06-14-2000, 02:41 PM
JimWest JimWest is offline
Default Re: wave out\'s api windows standard
In the wave driver settings dialog, you have these options for using different ins and outs on the Digi-001 (when using software apps other than PT LE):
Ch 1-2 Format control
Here you may choose between different types of I/O. When set to Analog, you can record into analog ins 1 & 2 and play back through both analog outs 1 & 2 and the S/PDIF RCA outputs. When set to S/PDIF, you can record into the digital S/PDIF RCA inputs. When set to ADAT Optical, you can record into the first two channels of the ADAT optical input. When set to S/PDIF Optical, you can record into the S/PDIF optical input. [See Sync Mode in the I/O Setup Dialog description below for info on syncing to the digital input stream.] In S/PDIF, ADAT Optical, and S/PDIF Optical, you can play and record monitor through both the respective digital outputs and the analog outputs.
Jim West
Digidesign
HD wave drivers windows 7 Wawili_Sound Pro Tools TDM Systems (Win) 7 12-21-2010 08:57 PM
Wave pool and other windows (Can't find them) AlohaMoto Pro Tools M-Powered (Win) 1 05-04-2007 06:46 PM
Wave Drive for MBox with Windows XP Pro Rufino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-19-2003 06:04 PM
wave driver for windows 2000? Kris75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-14-2002 07:40 PM
WAVE PLUGINS & WINDOWS XP PRO Ryan H. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-02-2002 06:22 PM
