Old 05-03-2015, 01:40 AM
bzerk bzerk is offline
Default the current playback engine does not support a sample rate of 44.1 khz
was getting this message (the current playback engine does not support a sample rate of 44.1 kHz).. did what other posts on this page said to do and that did not work so I uninstalled the mbox and now I am stuck. Should I uninstall pro tools 12? I only brought the upgrade and ionstalled it to my new computer (windows 8) 2 days ago.
Old 05-03-2015, 05:12 AM
amagras amagras is offline
Default Re: the current playback engine does not support a sample rate of 44.1 khz
There are some other threads about this, the solution given by Avid to me was to plug in a pair of headphones on the onboard sound of your computer so the OS wont share your ASIO interface with Protools.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 05-03-2015, 05:16 AM
Klastorpet Klastorpet is offline
Same problem!
But..
Win 7 pro 64
PT 11.3.1
Mbox (3rd Generation) Firmware 1.0.8
Cant open any old sessions..
New -no prob..
Feels it is a Hub connection problem..
________________________
Klastorpet
System details
Old 05-03-2015, 05:35 AM
Originally Posted by Klastorpet View Post
Same problem!
But..
Win 7 pro 64
PT 11.3.1
New -no prob..
Can you open recent sessions? Maybe just the ones that are on 48? I'm running Win 7 pro x64 too with a Fast Track USB and the trick with the headphones jack plugged into the onboard audio out solved my problem... It's not elegant but it works.
amagrasmusic.com
Old 05-03-2015, 06:29 AM
I been fibbling now with everything.. so now i cant open a new proj..
tried to uninstall PT and re install it.. Probably the easy way is to Format the c: and start from the beginning..
The problem can haw with i first tested a KORG mini keyboard and switched it to a Launchkey..
but the problem is that PT cant HUB control the Mbox..
Under PT Setup, Hardware setup, the Sample Rate is not "active"
Mbox "Launch control panel" (from PT Hardware setup) works, but Sample rate is not adjustable..
Klastorpet
System details
Old 05-03-2015, 06:52 AM
Perhaps your computer does not have onboard sound card but... Did you tried what I said? You can also trash your PT preferences.
amagrasmusic.com
Old 05-03-2015, 06:56 AM
ArKay99 ArKay99 is offline
Just throwing this out there... Are you, or can you try running the MBox on USB 2.0?
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2.
Old 05-03-2015, 07:16 AM
no USB 2..
but everything ells works.. even PT 10 works.. (with some other fault, because the session is for 11..)
anyway, I think I jump the fault search and just install a clean Win8 on a formatted C-drive..
The old sessions anyway needed some polish work, and i can just hope i don't need to go back to sibelius MIDI status..
Klastorpet
System details
Old 05-03-2015, 07:27 AM
no USB 2..
Well... When the fever of reinstalling Windows gets you, there's nothing else to do... I would trash the preferences and try to make Windows to use the onboard sound so it doesn't conflicts with the Mbox, before.
Been there, done that, I just hope it works in your case.
amagrasmusic.com
Old 05-03-2015, 07:50 AM
Re installed the (un-used) motherboards "internal"spdif and told Win to use it..
so now i got it to "work"!!
perfect!
Just do the session upp to lv and export everything and do a clean install on a frech/clean drive!
probably my swearing helpt
Klastorpet
System details
Current Playback Engine does not support sample rate sharpo07 Pro Tools 11 7 01-08-2016 05:32 AM
The current playback engine does not support a sample rate of 48 kHz. allegrarc macOS 9 11-27-2014 09:43 PM
The current playback engine does not support a sample rate of 48 kHz oNeKOG Third Party Interfaces 3 09-08-2014 04:36 PM
the current playback engine does not support a sample rate of 47.9 kHz mikevarela Post - Surround - Video 3 03-30-2013 09:26 AM
The current playback engine does not support a sample rate of 44.1 khz murdafew Pro Tools M-Powered (Win) 4 05-14-2010 03:21 AM
