Pro Tools disappears when at desktop
This has happened 3 times now in the last 7 days! i've minimised PT and go to the desktop to do some backups etc and Pro Tools disappears. 8.0.4 snow leopard 10.6.4 crash log and dlog if anyone wants to check it... http://www.sendspace.com/pro/avsaha header of crash log... Exception Type: EXC_BAD_ACCESS (SIGBUS) Exception Codes: KERN_PROTECTION_FAILURE at 0x00007fff702dea20 Crashed Thread: 1 Application Specific Information: Analyzing process: Pro Tools HD[182], path: /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/MacOS/Pro Tools HD; parent process: launchd[130], path: /sbin/launchd Thread 0: Dispatch queue: com.apple.main-thread 0 libSystem.B.dylib 0x00007fff80e8ceb6 __semwait_signal + 10 1 libSystem.B.dylib 0x00007fff80e8cd45 nanosleep + 148 2 libSystem.B.dylib 0x00007fff80ed9b14 sleep + 61 3 ReportCrash 0x0000000100007b66 0x100000000 + 31590 4 ReportCrash 0x00000001000013c0 0x100000000 + 5056 Thread 1 Crashed: 0 ??? 0x00007fff702dea20 typeinfo for CSCppSymbolicator + 0 1 com.apple.CoreSymbolication 0x00007fff8146823b CSCppSymbolicator::~CSCppSymbolicator() + 185 2 com.apple.CoreSymbolication 0x00007fff814680b8 CSRelease + 128 3 ReportCrash 0x000000010000731a 0x100000000 + 29466 4 ReportCrash 0x0000000100007dd7 0x100000000 + 32215 5 ReportCrash 0x0000000100009ff2 0x100000000 + 40946 6 ReportCrash 0x0000000100009dcf 0x100000000 + 40399 7 libSystem.B.dylib 0x00007fff80e97860 mach_msg_server_once + 378 8 ReportCrash 0x00000001000094d6 0x100000000 + 38102 9 libSystem.B.dylib 0x00007fff80e8b456 _pthread_start + 331 10 libSystem.B.dylib 0x00007fff80e8b309 thread_start + 13
Re: Pro Tools disappears when at desktop
3 times today so far!! go to desktop to do something and PT just crashes another crash log and dlog http://www.sendspace.com/pro/dd1bwv Weird one this!! never seen this problem ever and don't know where to start!! other than go back to leopard and 8.0.1 Chris
Chris -
Just looked at your logs - you have tons of incompatible plug-ins installed and definitely some that are known to be crash-prone. The logs almost certainly point to plug-ins being the culprit. Here's an example from the log: Quote:
Akoustik Piano - use the new Kontact Player 4.1 or higher BFD (full version) - looks like you have 1.5.x - you need 2.1.0 or higher bx_Control - you need 2.0.1 or higher bx_digital - looks like you have both v1.x and 2.x installed. Remove the 1.x versions bx_dynEQ - you need 1.2 or higher And so on. I'd go through the entire list, but I'm swamped at the moment. The plug-in compatibility grid is available here: http://avid.custkb.com/avid/app/self...p?DocId=343311 Compare your installed versions to the version listed in the far left column - if you don't have the minimum version listed, update it. If it's not on the list, remove it temporarily for testing and/or check with the manufacturer regarding compatibility. Make sure to trash preferences any time you change the plug-ins installed, so that all plug-in data can be recached. |
Pro tools 11.0.2 says unable to locate hardware then disappears | shamanrock | Pro Tools 11 | 6 | 11-16-2013 03:18 AM |
Desktop disappears when installing Strike | sricabla | macOS | 1 | 07-10-2013 09:15 AM |
pro tools 7.4.2 disappears when opening HELP! | JohnRyan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-26-2008 01:13 PM |
pro tools just disappears | chahende | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-13-2007 01:34 PM |
pro tools just disappears | chahende | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-13-2007 12:49 PM |
