#21
Re: 2019.5 Ultimate on a Mac Pro 5,1
I do think it helps renders. But don't quote me. I think final.cut uses the GPU for it as well as CPU. No boot up screen. Sometimes it gets stuck. And I have to power off with button on mac pro and restart. Then it starts. Only thing I don't like about this setup. No boot screen. Sent from my SM-G975U using Tapatalk |
#22
It's INSIGHT 2 (5.1) plug-in
I have MP 5.1, 2x3.33 cpu, 64GB RAM, SSD's and recently added RX 580 Pulse, OS 10.13.6. I have also found out that Izotope Insight is giving me A LOT of -9173. It is version 1.05c. I just reinstalled it today and during installation I got that OS error that this software is not optimised for my system, looks like 32 bit app! So I can conform that even if you put 580, you might still get those errors. But as I also use old Apple cinema display 20", I read here somewhere that those displays are giving troubles!? I will try tomorrow to swap that monitor with another one and see if that helps. I am using 4 displays and all other three are full HD resolutions. I would love to hear about some other metering plug in that will work in 7.1 or more without errors. |
#23
The RX 580 8GB is arriving tomorrow so will install that and then run insight and see. Since as of now, every time it's on the screen in 5.1 format only showing the levels, I get the -9173 If the GPU card does not address it, then I have no choice to upgrade to a 3.46 and mine as well re-do all of my ram to 6 x 8GB 1333Ghz too.
-Mac Pro 7,1 16core 3.2GHz 96GB -OSX 12.7.2 -PTHDN 2023.12 Ultimate -HD Omni -BM Intensity Pro -Waves Mercury+SSL4000 Collection+Abbey Roads -iZotope RX10 Advanced -iZotope Post Production Suite 6 -iZotope Music Production Suite 5 -HALO UP/DOWN MIX -ANYMIX -Delonghi Perfecta ESAM 5600.S |
#24
I did a vocal session today running at 64 samples. Never have I been able to do that in the past.
This has been the most stable version I have seen in years.
www.montabonsound.com www.29counts.com Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection |
#25
What Graphics card are you using, in which slot , thanks ?
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
#26
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
#27
If this helps anyone. My original Insight 5.1 (ver1 before ver2) works with no hiccups. The issue is you can't resize it to be super short and narrow at the bottom of the screen to watch levels like I can on the newer and supposedly more efficient ver2. The original one is square and much larger and overs a good portion of the edit window. but no -9173 popping up at all with it running for hours on end. Every now and then I will put the new Ver2 and....sure enough 9173
#28
Zero issues with Insight 2.
Might be the graphics card.
#29
Well, I mentioned Apple Cinema Display 20" I (was) using!
Yesterday I swap it with Samsung 22' TV, 1080p...and amazing thing happend; I was playing sessions on 128 buffer with NO errors. Then I load 5.1 session and cpu went to 100, RED. I change buffer to 512 and cpu was around 20%. Insight 1 was on one screen almost at full size. So it looks like those oldish Apple cinema displays are hogs for cpu. Also I had a older version of BX steromaker and updating to latest version helped as well. I am re-checking all the plug ins now and updating as we speak. But generally, it is good that we have 2019.5, shame about HDX voices, but I am sure it will come soon. |
#30
Anyway, good for you that it's working better...
Mac Pro 2 x X5690 3.46Ghz - 64 Gb RAM - SSD 256 Gb - SSD 1TB - OS 10.14.6 - Metric Halo 2882 + Lucid 88192 - Pro Tools Ultimate 2020.11 |
2019 ultimate and heat | mixer | Pro Tools 2019 | 27 | 05-23-2019 11:26 PM |
2019.5 Ultimate on Mac not seeing iLok license (and other possible problems) | Pete Gates | Pro Tools 2019 | 21 | 05-19-2019 10:40 AM |
D-Command & PT Ultimate 2019.5 | rmccam | ICON & C|24 | 5 | 05-09-2019 12:49 PM |
Vista Ultimate 64 (the ultimate dissapointment) | Filmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-03-2009 04:44 AM |
