Old 03-22-2011, 10:59 AM
jimst57 jimst57 is offline
Default Expansion Pack - SystemID?
I'm at work, and my Eleven Rack is at home.
I just bought and downloaded the Expansion Pack.
When I did so, I received a serial number and a system ID.
The machine I downloaded it from is NOT the machine I will running it on at home.
Will this cause me a problem? Or will I still be able to run it the one time at home?
Old 03-22-2011, 11:31 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Expansion Pack - SystemID?
you will be fine. i believe the System ID just locks the Firmwear updater to the PC that it is "installed" on, its not generated by an algorithm based on the componits of the PC you "bought" the ERXP on.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 03-22-2011, 12:02 PM
TheChimp's Avatar
TheChimp TheChimp is offline
(someone removed a post and mine didn't make sense any more...thanks Benoni for answering it!)
The Firmware Updater portion of the installer is tied to THE CPU YOU INSTALL THE FIRMWARE FROM (hence the 'System ID').
So you will have no problems. Make a copy of it from the machine you downloaded from, then run that copy on your Pro Tools system.
Note: You need to be online to complete the FW installation.
_______________________________
The Chimp
Delivery Manager/CSM, Guitar Products/AAX Plug-ins
P&S Creative Professional
AVID
Old 03-22-2011, 12:30 PM
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 03-22-2011, 01:00 PM
Benoni's Avatar
Originally Posted by TheChimp View Post
Ummm, that's not correct.
isnt that what i said?
I said is was NOT tied to the PC you "bought/purchased" the download with, and it is tied to the PC you installed on.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 03-22-2011, 01:11 PM
It worked fine.
I'm all set. Thanks.
Old 03-22-2011, 01:12 PM
Benoni's Avatar
Originally Posted by jimst57 View Post
It worked fine.
yeehaw! have fun man
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Do I have the Expansion Pack? strangedogs Eleven Rack 25 09-10-2015 10:41 PM
A.I.R Expansion Pack VIs Becharax Virtual Instruments 7 09-24-2012 10:59 AM
expansion pack pinnacle Pro Tools 10 1 09-05-2012 05:46 PM
need help with expansion pack eddie7314 Eleven Rack 2 10-08-2011 02:58 PM
11R Expansion Pack in UK? connor66 Eleven Rack 6 07-24-2011 09:11 PM
