32bit float (16.8)/(.24) import PROBLEM
I have not been successful at importing 32 bit float files. 32 bit float (16.8) is the Adobe standard, I would think PT 7.1 would be able to import it. Is protools able to import 32 bit float files?
This is the error I receive when importing 32bit (16.8): Could not complete the Import Audio command because Assertion in "\code\riptide_Gershwin_III\AlturaPorts\NewFileLib s\Ff\Audio\Processing\FF_AuLine 150 |
Re: 32bit float (16.8)/(.24) import PROBLEM
Pro Tools dose not see 32 bit files as a valid audio file.
You will ether need to have the files re-exported or use a file converting program to get them to a format that Pro Tools will see.
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
So there is no way to import a 32 bit float file directly into PT? There's no download that allows PT to recognize these files? If this is the case, I think this functionality should be added. Every other program I have recognizes this file type, including my quintessential media player.
Would it be a good idea to import into Wavelab or soundforge and then export as a 24 bit file? Would I loose any quality? Are there other better file converters out there? |
hi,
there are no downloads to enable 32bit float reading. whenever i get one of these, i use soundforge to convert it to 24bit ... and then i load it into PT. soundforge will use tri-dither and i've never noticed any difference in the sound quality myself. jeff |
Does soundforge automatically use the dither feature or do you use the batch converter process to dither? What's the appropriate way?
my understanding is it does it either way (batch or File->Save As....).
jeff |
Hi!
Pro Tools HD/TDM is 48 bit fixed (for all intents and purposes...) Therefore, it would not benefit from using 32-bit files. The only *real* benefit some see in this is to have the *original* file already in the format the app is running (currently, 32-bit float). With all that in mind...PT simply does not need the feature..unless you want to use another app instead...comrade... just kidding!
nikki k Eagles may soar, but weasels don't get sucked into jet engines. On the other hand, you have different fingers. |
I don't follow. If I am exporting files at 32bit float shouldn't that make a difference in the quality? then when importing to PT they should sound better than if I exported to 16 bit, I would think. With all that in mind...PT simply does not need the feature..unless you want to use another app instead...comrade... just kidding! I wouldn't trade TDM for anything. Couldn't even if I wanted to, I wouldn't get all the money I spent on this damn system back |
32-bit files benefit solely within the app. Since TDM is 48-bit fixed (and 24-bit as well- read the TDM MIxer whit epaper for more in depth info), 24-bit files would be the highest bit rate for any real world benefit.
There is a way to resolve, but it costs (unfortunately, and something I do NOT agree with): Digitranslator, and using AAF/OMF as an export from the other app, then import into PT. As was mentioned, alternately, and for whole files, simply batch convert does the job. I cannot see how anything *tangible* would be lost in a convert from 32-bit to 24-bit. As for import into PT: 24-bit or 16-bit will importfine. Which is better? Excellent question, and one with more than one answer. I prefer to work in 24-bit. Plenty of extra headroom, and it makes me feel more confident and happy, psychologically. That translates into better piece of mind, and thus one less thing to worry about. Coming from 32-bit files, I would suggest 24-bit all the way. I work with Nuendo 3.2 occassionally, and I use 24-bit. I tried 32-bit, and heard no benefit. My ears, my time, my conclusion. YMMV, of course...and hopefully it does. Individuality is law one IMO.
i agree with nikki-k .. i've used 32bit float wav files and i honestly
couldn't hear any difference between that and the 24 bit equivalent. and probably with good reason. telling the difference between the ~190db of dynamic range vs ~240db of dynamic range is likely going to be difficult to detect for the typical program material which we work with. typical music does not have anywhere near this dynamic range swing .... so you'll likely not hear it. in theory, you would only tell the difference if the tracks were massively saturated and perhaps not even then. you're in the ear damage zone. jeff |
Recording: 24bit vs. 32bit float | WombatStudio.Org | Tips & Tricks | 55 | 10-05-2014 03:41 PM |
Can old Accel TDM system handle 32bit float file format? | bobo mark | Pro Tools 10 | 3 | 10-21-2011 11:27 AM |
Import Audio not working - PT 8 on Win7(32bit) | Martine | Pro Tools M-Powered (Win) | 1 | 01-29-2010 11:22 AM |
The 32bit float advantage | ptnerd | Pro Tools TDM Systems (Mac) | 22 | 11-19-2005 10:26 AM |
24Bit Fixed Plug-in Buss Vs 32Bit Float | Matt_G | Pro Tools TDM Systems (Mac) | 20 | 08-02-2004 07:29 PM |
