Pro Tools/MPD24 hanging issues
Recently upgraded from the MPD16 to the MPD24 drum pad from Akai. I am running Pro Tools 7.1 software with Mbox 2 on a PC system.
anyone using this setup will help greatly, specifically the MPD24. As of upgrading to the MPD24 pro tools no hangs on exit and i have to restart windows xp pro to get my system right. This seems to be and issue with the way the MPD24 handles midi. it is the only thing i can think of. while runnning pro tools (with reason and battery 3) there is no problem. i have the mpd24 sending MMC messages to control the playback in pro tools. however when i am finished in pro tools and shut down (after closing reason), pro tools executable will not close, no matter what i do. and the only way to get out of this situation is by rebooting the computer. i did not have this problem with the mpd16, i have since uninstalled the uni quest software that came with the mpd24 but that has not solved the issue. i also notice that now when i open reason via rewire, some of my midi settings have been altered in reason, interestingly enough my m-audio radium 49 has no problems. again i only run into issues when shutting down pro tools, not while the system is up and running. thanks in advance. |
Re: Pro Tools/MPD24 hanging issues
**bump**
You'll need to give more information. How is the MPD24 configured in your system? Through the MIDI in/out ports? USB? I have a MPD 24 and I have no problems using it with my 002 rack. Can you post your cofiguration here?
pro tools hanging | supersam83 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-22-2010 01:49 AM |
Reinstalling after hanging issues... | pagan5000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 11-28-2008 08:33 PM |
AKAI MPD24 Won't work With My Pro Tools 7.1 (WIN) | jimmebeans | MIDI | 1 | 10-07-2007 11:27 AM |
CAN I USE MY MIXING FADERS ON MY MPD24 IN PRO TOOLS? | jimmebeans | MIDI | 0 | 10-02-2007 08:25 PM |
Pro Tools 6.4 Hanging | paitken | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-06-2007 09:04 AM |
