Old 11-16-2018, 02:02 AM
tonwurm's Avatar
tonwurm tonwurm is offline
Default internal sata drive doesn´t show up after restart
I run a dualboot system (Mavericks / Sierra), both on a dedicated internal ssd. I bought a new internal hard drive (Western Digital WD Black 4TB) for Libraries / Samples.
After starting the mac all disks show up but if I choose to restart from the other system-drive the Western Digitak Disk doesn´t mount and it´s not shown in the disk utility, too. I have to shut the mac down. Then after rebooting all disks are back again. Also if I do a restart but not changing the startup disk the disk comes up without problems. So the problem only occurs by doing a restart by switching the system drive.
Does someone have any advice how to fix this issue ?
Thanks in advance
MP5,1 12core 3.46ghz 96GB
Ultimate HDX
https://www.youtube.com/channel/UCIA...Rnu0Jfh-YsgftQ
Old 11-17-2018, 05:37 AM
tonwurm's Avatar
Default Re: internal sata drive doesn´t show up after restart
no one, no idea ?
Ultimate HDX
Old 11-17-2018, 03:29 PM
Tweakhead Tweakhead is offline
What is the specific format of this problematic drive ?
Did you do it yourself, or just use it as it came out of the box ?
Old 11-18-2018, 02:30 AM
tonwurm's Avatar
thanks for answering
I put it in one of the internal drive slots of the mac pro and formatted it with disk utility
I attached screenshots with system information about this specific drive
Ultimate HDX
Old 11-18-2018, 05:13 AM
Thanks in advance
I dual boot my 2012 MacPro into either Yosemite or Sierra and my drives all show up okay in Finder and Disk Utility. I don't have them show on my desktop though. I have two WD Blacks 4 TB each with 64 meg cache - yours have the 128 meg cache in the internal drive bays 1 and 3. I boot from a Samsung 850 EVO 1 TB that sits on a pcie adapter card and that ssd is split into two equal boot partitions.
I don't understand something - are you booting off two separate drives - one for Sierra and the other for Mavericks? If so where are those drives? It looks like you have five drives which would mean you either have one ssd on a pcie card or a drive sitting in the lower optical drive bay.
Where are you selecting which drive to boot off of? System preferences or holding down the option key on bootup?
Old 11-18-2018, 10:27 AM
I don't know why it is displaying an MS-DOS FAT32 Volume.
I would reformat as 1 partition.
Note: I hate the Sierra Disk Utility, so reboot into Mavericks.
Launch Disk Utility.
Select the actual mechanism.
Choose the Partition tab.
Create 1 Partition - Mac OS Extended (Journaled)
See if that gets rid of that weird EFI (MS-DOS FAT32) & POOL 2 split.
Old 11-19-2018, 01:12 AM
tonwurm's Avatar
Yes this is correct . I have 5 drives using in addition the lower optical drive bay. I have for Sierra a dedicated ssd drive in one of the internal bays and also a seperate ssd for mavericks. I switch the boot drive with a apple script that I found in the web since I cannot selct in mavericks the sierra drive as startup volume. Sometimes I also use the option key during startup which also works
Thanks for answering !
Ultimate HDX
Old 11-19-2018, 01:14 AM
tonwurm's Avatar
Strange ... all my internal drives have that EFI partition and running since years without problems. But I will try that. Thanks !
Ultimate HDX
Old 11-19-2018, 04:11 AM
But which procedure is giving you the problem? Using the script you found on the web (who knows how safe/good that is?) or the option key on boot up? I would stick with the option key on boot up. It takes a little longer to bootup but is a known good method. And I'm guessing the Mavericks ssd is also in a drive bay right?
Old 11-19-2018, 04:23 AM
tonwurm's Avatar
I wrote it in my first thread post: after the mac was completely shut down and then start (no matter from what system drive) all drives apear correctly. And there´s also no problem if I then restart from the same system drive again. All drives appear then, too. BUT if I restart the mac from the other system drive than that which is currently running (f.e. Sierra is active and then restart from Mavericks) this very WD 4TB drive doesn´t appear again. I noticed that the drive doesn´t spin up.I have to shut the mac down and restart to make it active again
Ultimate HDX
Better to record to a FireWire drive? or 2nd Internal SATA HDD? conrad787 macOS 13 06-21-2012 08:52 AM
ProTools Boot drive migration to a new internal SATA drive audiowave Pro Tools TDM Systems (Mac) 1 05-03-2011 03:45 PM
PTLE w/ Mac Pro - Internal SATA drive order? salmonsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-07-2008 05:57 AM
Another Firewire Drive or Internal SATA II Drive??? fenderguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-14-2007 01:44 PM
External Drive writing to Internal SATA Drive Teen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-16-2007 07:29 AM
