AAX DSP plugin latency
Is there an AAX DSP plugin latency database anywhere?
I'm looking for some latency numbers on bx_console at 44.1. Lots of the old manuals included instance charts and latency info. Now I only see it for Waves and a couple other companies. None for AAX DSP. I'd be happy to help initiate it with the latency and instance numbers I have. Interest? Anyone have bx_console they can confirm latency on? Numbers on Oxford EQ would also be appreciated. There's certainly a growing number of us that care about latency and a bit of a plugin buyer's guide for AAX DSP would be helpful. Thanks! |
Re: AAX DSP plugin latency
Ah, thank you!
All are 96K/24bit session values (though mostly these have stayed the same when I look at 44.1kHz)....
AVID: Channel Strip = 10 EQ3 = 10 Pultec = 10 All BF = 10 Dyn 3 = 10 Fairchild = 10 Impact = 10 Pro Comp = 10 Pro Exp = 10 Mod Delay = 10 Real Tape delay = 10 RectiFi = 10 Real Tape Sat = 10 SciFi = 10 purple 77 = 13 Smack = 11 Pro Multiband = 34 Pro Limiter = 73 Gray Comp = 34 Black Spring = 66 Dverb = 34 Reverb One = 66 Revibe = 66 Space = 66 Studio Reverb = 66 Tape Echo = 66 SansAmp = 63 Black shiny Wah = 34 C1, Flanger, Orange Phasor, Vibe Phasor = 66 Real Tape Flanger = 4811 !!!!! Roto Speaker = 34 Distortion Pedals (all) = 66 Pro Subharmonic = 394 METRIC HALO Channel Strip = 10 SOFTUBE Summit EQ = 34 Summit Grand Ch = 38 Tube Tech Classic Ch = 38 Tube tech pultecs = 42 FET Comp = 34 From a fellow source I have talked with about this... PLUGIN-ALLIANCE XLA-3 = 76 BX Limiter = 348 Refinement = 76 Saturation V2 = 56 All Elysias = 76 SPL PassEq = 60 SPL Vitalizer = 60 VSM-3 = 76 All others are 34. From memory of recent demo of McDsp all were at least 34.... On a side note - amazing how the OLD Avid ones are all a mere 10 samples (were even less in the TDM versions). Now - no one does better than 34 samples. Three of these takes a stellar 0.52ms basic mixer to the same as HD Native at 96kHz 64buffer...
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
I remember a few TDM plugins (Pre-ADC) were 0 - gone are the days of DSP optimization with ADC
Could someone please post the delay for Oxford EQ at 96kHz. I have the old TDM and AAX native ones and the upgrade is $75 to do HDX (kind of steep for a single EQ upgrade!). If its 34 samples like almost everyone else nowadays I am less compelled... PS - they won't let me do the current demo cause I already own the product ... brilliant!
DSP latency is never zero. It takes one sample to bring the data into the DSP chip, another sample to process, and third sample to put it back to Native. Theoretical minimum 3 samples, which is why many TDM plugins showed 4 sample latency just to make sure they have enough time to process the audio in 2 samples instead of 1 sample.
Why is the lowest AAX-DSP plugin 10 samples (when they used to be 4 in TDM)? And why are the newer AVID Pro ones the only newer 10 sample plugins? And why is no plugin from 3rd party (except the old MH Channel Strip) less than 34 samples?
At 96k, it's 10 samples. For EQ3, EQ 5 and the filters. Cheers! |
^^^^^^^^^^^^^ Thanks much!
plugin latency in pt8? | CrAkD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-17-2009 06:33 PM |
Plugin latency | Mac Shack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-07-2005 09:44 AM |
Plugin Latency | derF | Pro Tools TDM Systems (Mac) | 1 | 04-05-2003 07:12 AM |
Plugin latency | Ben Jenssen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-13-2002 06:32 AM |
Unity DS-1 and Latency... Anyone else feel the latency makes the Plugin unusable? | Mt.Everest | Pro Tools TDM Systems (Mac) | 7 | 08-26-2001 04:53 PM |
