Recording on external drive
I have a mac book pro, and I do not have enough space on it to record pro tools sessions. If I bought a firewire 800 external drive, would it be fast enough to record pro tools sessions on it while my mbox is plugged into the fire wire 400 and pro tools is running off my main drive?
Another very important concern I have is this. If I used an external drive that required a power supply, would I get noise coming through my monitors? Thanks. |
Re: Recording on external drive
It will work fine. In fact the way your asking is how it's done even at big recording studios. |
Personally, I like the expresscard option because it puts the interface and drive on 2 totally different busses. That is how I run my setup. J |
Most important is to get a external hard drive that is 7200 RPM. Many of the small drives are only 5400 RPM, the full size drive most are 7200 RPM.
Steve B. ---------------------------------------------------------------- If you think you can or if you think you can't, you're right. |
http://eshop.macsales.com/shop/hard-...te-al-pro-quad J |
Antonio Corcella [email protected] www.myspace.com/ajaproductions www.ajaproductions.com |
Also, can't really expresscard on an iMac |
I have a really interesting article for you to check out. http://episteme.arstechnica.com/eve/...m/983007706931 One of the engineers I work with always talks about the 800 to 400 drop down. It does kinda suck, that is why they are phasing out 400 ports. There is a lot of discussion of this design "flaw" around the web, especially in pro audio.
Recording to a external SSD drive.. | Southsidemusic | Pro Tools 10 | 7 | 11-29-2013 05:59 PM |
USB 3.0 for external recording drive | CalebB | macOS | 12 | 09-05-2012 12:42 PM |
Recording to an external drive via USB in LE | AJStopSixMoniiBabii | Tips & Tricks | 2 | 11-15-2010 08:03 PM |
Is an external drive superior to a 2nd internal drive for recording with Protools? | beyoutofull1 | Pro Tools M-Powered (Win) | 4 | 03-03-2010 06:08 AM |
should i be recording on my external drive | 16yearsjeff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 06-03-2003 08:13 AM |
