Old 01-29-2023, 09:43 AM
RHKfilm RHKfilm is offline
Default Tempo/Beat Detective not honoring 2/2 meter
I set a measure to a meter of 2/2 using beat detective but the functionality is broken. The click and the generated tempo still calculate and operate in 4/4.
For instance, if I make a 1 measure selection and use beat detective to assign that section the following:
Start Bar/Beat 86 | 1
End Bar/Beat 87 | 1
Time Signature 2/2
Then click Generate, it doesn't adjust the timeline correctly. The timeline will show the selection ending halfway through Bar 86. This despite the meter display showing as 2/2 and the click following the meter.
Am I expecting too much of PT? I want to be able to insert any meter and tempo for any measure but I have experienced nothing but bugs whenever I try such trickery.
Old 01-29-2023, 02:35 PM
_JJ_ _JJ_ is offline
Default Re: Tempo/Beat Detective not honoring 2/2 meter
I don't know about beat detective so not much help there. But 2/2 = 4/4. The note values stay the same either way and so would the 1/4-note resolution of the click or grid, which I think you would need to change elsewhere. Does that make sense?
Old 01-30-2023, 08:47 AM
Beat Detective is for generating tempo events - IIRC (it's been a bit since I was in the BD dialog) the bar/beat/meter entries in Beat Detective are for setting the analysis range. Meter events should be entered in the meter ruler.
http://www.richbreen.com
Mac Studio / Ventura, MacPro 5,1 Dual Hex, Mojave, PT 2022.12 HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio / Monterey / HDX / MTRX / S6
Tempo mapping Beat Detective or identify beat? grateful 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-14-2012 09:13 PM
beat detective and tempo kevinsimons 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-26-2009 04:57 AM
Beat Detective, Beat markers to Tempo Ruler?!? phobia Tips & Tricks 3 01-01-2007 01:31 PM
Using Beat Detective with Tempo Changes WStarnes Pro Tools TDM Systems (Mac) 0 12-05-2006 11:22 AM
Beat Detective/Tempo Changes jeff...ya know...jeff Tips & Tricks 3 01-22-2003 06:31 PM
