I was thinking maybe something to do with the keyboard channels. Recording 'any' would play through, but on playback maybe everything is on a different channel from the output selection. That wouldn't explain it working when the insert is moved though. Interesting. Anywho, check what channel your keyboard is assigning.
PT 2022.12 DP 11.21 MOTU M4 HP Envy 8G i7 Quad Laptop Win11 PT 2022.12 DP 11.21 828es ADA8200 MTP-AV HP Z2 G4 Xeon Workstation Win11 2011 Mac Mini i7 Quad High Sierra.6 VEP 7.x hosting various VIs |
Thanks ChuckS, I'll have a look.
Dan |
I have had similar problems for years on my Windows machine with a Saffire interface, especially with RAM-hungry sample-based VIs such as Spitfire's. My workaround is to do one of two things: wait 30 seconds or so and try again, or deactivate and reactivate the VI. I do the former if I need to get up for a moment anyway.
I have noticed that the problem becomes more frequent as the complexity of the orchestration increases. In other words, it seems to be related to load. We're both using Firewire interfaces. Aging tech. Possibly a coincidence but... ![]()
David J. Finnamore PT 2022.9 Ultimate | Clarett+ 8Pre | macOS 13.1 on a MacBook Pro M1 Max PT 2022.5 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
![]() Quote:
Bob Without a song The day would never end |
#16
I have this issue and it's dramatically worse in 2022.12 vs 2022.10 to the point where bounces have been affected and it gets hard to work.. rolling back to 2022.10 right now for this reason and it seems to be much better if not completely better. some instruments are more affected than others, east west Opus and Arturia Analog Lab do it constantly.
see if 2022.10 works better for you? 2022.12 didn't solve the bugs it seemed like it would for me re: MIDI and h264 export crashes so jumping back to .10 here for now MacBook Pro 16 M1 Pro OS 12.6 Monterey |
#17
Interesting. Maybe I'll give 2022.10 a try.
As an update to my situation, Avid support finally got back to me to arrange troubleshooting, but of course everything is behaving as it should. After weeks of trouble with midi, I now can't reproduce the issue... Dan |
#18
This bug is in the top 3 of the most frustrating bugs I run into. I have little hope it will ever be fixed because it happens so randomly that I can’t list steps to reproduce it. But there are a few things that I have noticed.
1. It happens more often when my buffer settings are set to 64 or 128. 2. It seems virtual instrument related. For example, it happens very often for me with Alicia Keys in Komplete Kontrol or Kontakt. 3. When I am having the issue, it usually starts happening an lot. If you keep hitting playback in the same spot of the timeline, it won’t play. The way I get it to start working again is by playing back in different places in the timeline. 4. When the issue is happening, it is common that the instrument giving the problem will not play after a bounce. This is scary for cases where you are doing multiple bounces because sometimes the instrument will not be included in the the following bounces unless you wake up the instrument again. I hope it somehow gets resolved.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2022.12 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.6.0 Noisebox Studios -Utah Recording Studio |
Why are MIDI notes 1-2 samples ahead? 2022.9/2022.10 | gthm | Pro Tools | 4 | 11-19-2022 07:25 AM |
Pro Tools Studio 2022.9 problems. Please help me | Simonluka | Pro Tools | 16 | 10-20-2022 09:52 AM |
Two Big Problems with 2022.4 | HowHoffman | Pro Tools | 8 | 10-19-2022 07:57 AM |
Mac Studio M1 Max Problems with 2022.5 Playback Engine | operator | macOS | 7 | 06-24-2022 08:43 AM |
Crash moving tracks to new Routing Folder in PT 2022.4 [FIXED 2022.5] | Dizzi45Z | Pro Tools | 43 | 05-29-2022 03:59 AM |
