Old 01-28-2023, 04:53 AM
bonzerboy bonzerboy is offline
Default Panning VI questions
Someone told me always use VI as stereo instrument track. Reason is you would get more options later in mixing. My question is if you have many VI in stereo is to good to say pan the VI L & R channel to same position ot does it build up to much volume or freq? Another question is would it be better to bound down to mono summed or multiple mono and delete one track? I did try bouncing down some VIs to mono summed and it seems like it changed the sound. Curious of any tips..
Wow am I groovy or what
Old 01-28-2023, 06:57 AM
Ben Jenssen's Avatar
Ben Jenssen Ben Jenssen is online now
Default Re: Panning VI questions
I think you are over-thinking this. Some VIs can be mono, but most are stereo only. Yes, if you want it to be mono, center left and right, and bounce if you want. If nothing is wrong, it should sound just fine. You can record it to a mono audio track if you want. Stereo VIs act no differently from stereo audio tracks. Just get on with it. No offence.
Mac mini M2 base model, 16GB RAM. MacOS 13.2.1.
PT Studio 2023.3.
2 x Artist Mix, SSL UC1, Avid Control on iPad.
Old 01-28-2023, 07:27 AM
JFreak's Avatar
JFreak JFreak is offline
There are two types of stereo instruments.
First, true stereo which for example emulate orchestra. Flute is there in the stereo image where it usually sits in a real orchestra. This I would let be wide open and if necessary modify the stereo placement within the instrument (if possible).
Second, stereo instruments that do some widening or other modulation to be stereo. This you should treat just like a regular reverb. For example instead of wide open, place one instrument to full left - dead center and another instrument dead center - full right.
Janne
Old 01-28-2023, 04:40 PM
I also always(?) keep VI's as stereo tracks, but don't always pan hard left/right. Just my 2 cents; I consider my stereo field(what I hear from my stereo monitors) as a virtual stage. So, as an example, a grand piano does not take up the entire stage, so I might pan it 10 and 2 o'clock, or I might push it off to one side as in 11 o'clock and 5 o'clock. Of course, there are no rules here, only ideas
Old 01-29-2023, 05:42 AM
Thanks for the replies some things to think about and yeah over thinking is what I do LOL
Old 01-29-2023, 05:51 AM
Here is another question from my over thinking mind if you are to bounce a stereo VI to make it mono does it matter if you center bot pans or npot?
Old 01-29-2023, 07:03 AM
K Roche's Avatar
K Roche K Roche is offline
Sorry but "always use stereo instrument tracks" is not a hard and fast rule
because there are no rules.. That said
Now while it is true that you can always pan a stereo track to the same side and number position it is also true if you know you are going to want some instruments in mono you can just put them on a mono track
In my session templates that include instrument tracks I usually have 2-4 mono and 2-4 stereo,, tracks ready to go
just my 2 cents
System :
Avid Carbon interface , PT Ultimate 2022.10 .....Mid 2020 iMac 27" 3.8GHz 8-core i7 10th Gen processor,,128GB 2666MHz DDR4 memory,,2TB SSD storage,,Radeon Pro 5700 XT with 16GB of GDDR6 memory,, on Monterey 12.5.1
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
Old 01-29-2023, 07:17 AM
Sure. If R and L are significantly different, you most often want them both in the mono bounce/print. So you pan them both to the center or one side, and you have your summed mono.
PT Studio 2023.3.
Old 01-30-2023, 03:13 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Someone told me always ...
Be careful of the absolute. Is this person the Omnipotent?
Regarding the stereo / mono!
  • What is the source?
  • How many mics used?
  • How was is mixed to get the VI?
  • What options are in the VI for mixing?
  • What are you trying to achieve?
  • What type speakers are most listening of the intended audience listening to [one/two/multiple(s)]?
Every absolute statement brings more questions, absolutely!
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
Subscription free, forever!
Old 01-30-2023, 08:54 AM
As for bouncing or committing, I would bounce/commit as stereo and treat the pan knobs the same as on the instrument track. That way, if later on you change your mind, you aren't stuck with a mono track
Eucon 3.4 panning window MC Control Unit questions Cryos Artist Series 4 05-20-2016 10:42 PM
Panning law for TV antonis Post - Surround - Video 2 11-16-2014 06:23 AM
Some Panning questions cyndiek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-04-2009 08:28 AM
stereo panning and EQ questions Bixby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-12-2003 09:46 AM
Dverb and Panning (2) questions Bill Sanders 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-30-2003 05:32 PM
