Old 01-19-2023, 05:55 AM
CraftWW CraftWW is offline
Default Re: Playback stopping when ..
A colleague of mine found a hint at the Pro Tools installation website I oversaw...
They seem to know about the bug:
"Ventura + Monterey - System Sound can cause streaming errors. To avoid, turn off “Play user interface sound effects” in the “Alert and Sound Effects” section of System Settings. This will not turn off all 3rd party application notifications, and so it is also advised to go into each application settings/preferences and turn off notification sounds to avoid this issue. For example, go to Outlook’s preferences, “Notifications and Sounds” and uncheck the “sounds” item.
Outlook notification sounds preferences window"
It´s on: https://avid.secure.force.com/pkb/ar...2-Release-Info
Old 01-19-2023, 06:47 AM
mattrixx mattrixx is offline
That's a very clever workaround
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFXII / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 01-23-2023, 06:32 PM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
too clever! love it.
Originally Posted by CraftWW View Post
I found a little workaround so that my main desktop bridge interface keeps playing audio flawlessly ...
In Ventura there is an Accessibility setting where you can generate relaxation sounds. I put it on uniform noise (translated) and dimmed it completely (no sound at all) but it keeps the interface active
http://www.ainsliegrosser.com/
MacBook Pro 2019 64GB OSX 10.15.7, HDX, Sonnet Chassis, PT Ultimate 2022.9, S3, Dock, MTRX Studio
Old 01-30-2023, 07:59 AM
The new Ventura 13.2 update arrived and made the issue a little more unobtrusive.
When using more than 512 samples buffer in the Pro Tools playback engine the break is almost inaudible. Just sometimes it halts for a sec or two when a new audio interface is activated or deactivated in the background.
Normally I can record on 64 samples ... I always like to be more latency free during voice recordings.
Old 01-30-2023, 09:20 AM
mwongsound mwongsound is offline
Ive run into the same problem as well testing Ventura 13.1 and 13.2 on a Mac Pro 2019 with Protools 2022.10 and then again on 2022.12. It's definitely the operating system sound request taking audio priority over the other audio drivers. Easily reproduced by playing a track in protools then going to system preferences sound panel and changing an alert volume.
This problem was introduced by Apple so I think we'll have to make enough noise for Apple to correct it in a system update.
Has anyone tested this yet on an M1 or M2 running the Silicon beta?
Old 01-31-2023, 02:31 AM
I can just tell that I have a M1 MacBook Pro and there is the same issue running the new mac silicone based beta on Monterey and even when you use the regular "Rosetta2" Pro Tools App the stutter in activating interfaces is there.
Prior to Monterey it was all fine
Old 01-31-2023, 06:14 AM
Yes, that definitely seems to be the case. It's not affecting just Pro Tools either. I've seen odd behaviour with sys sounds affecting Logic too.
Matt McKenzie-Smith
mattrixx.net
Old 02-01-2023, 08:37 PM
This is annoying as hell. Even if you have everything turned off, it will do it. So it's the sound itself.
So it's definitely the call to the error (mwongsound mentioned earlier), not the playback itself.
Matt McKenzie-Smith
mattrixx.net
Old 02-01-2023, 11:55 PM
I've just spent some time on the phone with Apple and have had this raised to engineering, so will hopefully get an update on this in the next few days.
Will update, when I know more.
Matt McKenzie-Smith
mattrixx.net
Old 02-02-2023, 06:07 AM
I´m going back to Big Sur now. I erased the HDD , done a fresh install of the OS and now reinsert my time machine backup. That OS was more stable...
FX propagation after stopping playback kirkbross Pro Tools 2019 1 01-12-2020 08:04 PM
Random stopping of playback... 12.8.2 R2 SevenRising Pro Tools 12 0 10-20-2017 12:15 PM
Skipping playback (stopping/starting during playback) sKjF Pro Tools 12 12 11-12-2016 06:28 AM
Playback/Recording stopping immediately newaudiogirl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 08-06-2007 10:57 PM
Stopping playback returns transport to zero? TimInVan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-13-2002 04:49 PM
