Old 06-04-2020, 03:13 PM
PT8716 PT8716 is offline
Default Re: Sample Tank 4 in PT 11 - not loading
I'd update but every other plugin loads fine and my system runs flawlessly. I have a ton of VIs that load and run without issues. Hmmm...
Old 06-05-2020, 03:35 AM
Originally Posted by PT8716 View Post
I've been having the same issue. SampleTank 4 unable to load and gives AAE error 14018 I'm running PT 11.3.1 on Windows 10 Pro and I never have issues with my system. I have a ton of plugins from various companies and that includes VIs. I've run huge session with a ton of plugins and it doesn't break a sweat. SampleTank 3 & Syntronik run fine. ST4 loads fine and runs in Reaper, Cakewalk & Waveform on the same machine so I know it's a PT issue.
It comes back to incompatibility between PT 11.3.1 and Win 10. I don't care that everything else seems to run okay on your system; incompatibilities can happen in the strangest ways. Just because others may have no issues (so they say) that doesn't mean things will run okay on your system. There's a reason Avid does compatibility testing.
Jack
QAPLA!
Sample Tank Help soulrebel718 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-07-2005 11:53 AM
Problems Loading Sample Tank Dog Tales 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 04-14-2004 06:37 AM
another sample tank bug? rogga_bogga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-25-2003 11:05 AM
PT hangs when loading Sample Tank guentherschmidt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 29 09-29-2003 10:49 AM
sample tank and pt le j creasey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-26-2002 01:21 PM
