Old 10-09-2023, 02:09 AM
samplaire's Avatar
samplaire samplaire is offline
Default 2023.9 Drag'n drop stereo file results in 2 mono tracks
It occured after updating to 2023.9. This is new in 2023.9, never seen it before, haven't touched any setting since the updating from 2023.6. From desktop or clips. Is it a bug or a new feature which you disable/enable anywhere? TI haven't seen such behaviour for years.
Mac Studio M1 Max 32/512, 2x 2TB 40Gbps + 2TB 10Gbps, 13.6.5, Logic 10.8.1, PT Ultimate 2024.3, Mackie Big Knob Studio+
Old 10-09-2023, 03:30 AM
tope d's Avatar
tope d tope d is offline
Default Re: 2023.9 Drag'n drop stereo file results in 2 mono tracks
In the Session Setup Window, is the Interleaved checkbox enabled?
-Tope
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 10-09-2023, 06:13 AM
samplaire's Avatar
Yep, confirmed. As I said, this was not present in 2023.6
Old 10-09-2023, 09:22 AM
This is not a change in 2023.9. I've been busy dragging and dropping stereo tracks into 2023.9 on Mac since the day it was released... if something like this, that is so frequently used, was broken in 2023.9 you would likely have other folks screaming about it on DUC.
This is a perennial issue that comes up every now and again, for example see https://duc.avid.com/showthread.php?t=369237 or many other threads about this. And if it's a file name or source file format problem and it's behaving incorrectly please file a bug report so it can get fixed.
Old 10-09-2023, 02:37 PM
moogboy100 moogboy100 is offline
Lemme guess. Audio files came from Cubase.
🖥️ Pro Tools Ultimate 2023.12.1 | Mac Studio M1 Max (64 GB) | Ventura 13.5.2 | Focusrite Red 4Pre
💻 Pro Tools Ultimate 2024.3.1 | MacBook Pro M3 Pro (18 GB) | Sonoma 14.4.1
Old 10-16-2023, 02:45 PM
samplaire's Avatar
No, just plain mp3 or wav. As I said, this was not present in 2023.6.
Old 10-17-2023, 08:32 AM
Reckless Erik Reckless Erik is offline
...and you dragged to a stereo track?
[email protected]
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Old 10-17-2023, 01:41 PM
samplaire's Avatar
Nope, my problem is when dropping to the trackless area.
Old 10-17-2023, 03:31 PM
Some things to try
Create a new macOS admin account. Log into that account. Create a new empty session, repeat the test there. (No need to trash prefs, the new account effectively does that and more).
Still problems can you share the file that is causing this behavior? Or make another one? Even if it seems to be every mp3 you have lets exclude that as this behavior in the past is often input file related.
Old 10-18-2023, 01:55 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Agreed. I'm on PT 22.9.0.112 and I've seen this with Loopcloud samples on occasion.
Create a stereo track first is the way forward.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
2023.6 Drag&drop from workspace bug with special characters foret_sombre Pro Tools 3 10-04-2023 08:43 AM
Import stereo file generates two mono tracks ?!?! frenchman Pro Tools 2020 10 09-04-2020 07:55 AM
separating 2 mono tracks from a stereo file nibtgom Pro Tools 10 4 10-13-2016 06:17 AM
Can't drag mono file out from stereo track? Nathan W. Pro Tools TDM Systems (Mac) 1 10-14-2009 01:31 PM
Stereo File Drag 'n Drop from workspace bug? Rich Breen Pro Tools TDM Systems (Mac) 0 11-09-2004 01:01 PM
