Old 12-27-2022, 01:37 PM
koka koka is offline
Default Virtual Instruments tracks not playing all the time?
Hi All
I have strange problem for a couple of weeks Virtual instruments in Protools session not play all the time they suddenly stop to play?
Im using a lot of VIs in real time and Vienna Ensemble Pro 7 (lattest version)
Monterey 12.6.1 And Protools 2022.10?
Anybody have the same issue What VI can produce this bug?
Falon with Ravensoft Piano in session, Vacum Pro,Vienna Ensemble pro with 2-3
Kontakt instances?
Old 12-27-2022, 03:27 PM
Default Re: Virtual Instruments tracks not playing all the time?
There are known issues with VIs losing MIDI input, and maybe more, that have been discussed on DUC. I have no idea about use with VEP. Do you have problems if the VIs are instantiated locally?
Old 12-28-2022, 08:59 AM
Hi Darryl
Yes Im loosing playback with internal VIs specially offen with Falcon and Ravensoft 275 piano. With Vacum Pro ...
Just to mention that VIs dont loose midi asigments just not playing
all the time randomly...
Im in process to find what can produce this.
Old 12-28-2022, 09:06 AM
Maybe check this compatibility chart and find out that your system is not qualified, and I don't know what are VEpro requirements. But as said, losing MIDI assignments (midi tracks greyed out on edit window) is what I was instantly thinking.
Old 12-29-2022, 01:34 PM
In Compatibility chart say Monterey 12.5.1 and Im on 12.6.1
With Protools 2022.10 ?
Old 12-29-2022, 01:41 PM
Yes, it means anything later than Monterey 12.5.1 has not been tested and Avid Support is not going to be very helpful if you contacted them.
Old 08-02-2023, 02:39 PM
resonatee resonatee is offline
Hi Darryl
Check if you have All Automation parameters enabled on those plugins. Seems like pro tools is sending some automation parameters to virtual instruments and they looose their mind (because the settings get all scrambled) The solution is to disable auto-arming of all parameters for every instatiated plug-in (in Preferences) or removing them manually. Happens for me with Stylus RMX, EW Opus.....
__________________________________
cMP 2 x 3,46, 128GB Ram
Monterey 12.7.4
Metric Halo 3d 2882 I/O
Lucid 88192 with Blue Sky 5.1 monitoring
10gbE ethernet with True Nas storage
Old 08-14-2023, 09:04 AM
Stephen Bond's Avatar
Hi All
Kontakt instances?
Sounds like I have a similar issue. The MIDI playback fails when the CPU gets circa above 50% usage (PT metering) on my system.
No solution save reducing CPU loading gets it going AOK.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 08-14-2023, 11:47 AM
jeff1s jeff1s is offline
I have been dealing with this for a couple of years off and on.
I have a tech support ticket and the engineers are working on it. This has been a known issue for a couple of years, but since no one started a ticket, they assumed that it wasn’t that big of a glitch. Well, it has put me dead in the water more than a few times. According to the person who emails me, the engineers are feverishly working on a fix.
Old 08-18-2023, 01:28 AM
Interesting post Jeff. Are the working on the issue of the MIDI playback stopping for no reason or else the MIDI track routing is lost on opening a Session?
Stephen
Virtual Instruments playing AHEAD of the beat ansanity macOS 14 04-12-2022 12:47 AM
Some virtual instruments not playing back Eric.Yeung Windows 3 06-08-2012 03:01 AM
Playing Virtual Instruments Problem jaxsun23 Virtual Instruments 0 11-04-2009 12:10 PM
Playing Virtual Instruments jaxsun23 Tips & Tricks 9 01-02-2009 08:01 AM
playing multiple virtual instruments in a session explorationx Virtual Instruments 4 03-15-2008 06:49 PM
