Old 04-29-2012, 07:46 PM
zygmunt zygmunt is offline
Question Pro Tools 10 Distorted/glitchy/High Pitched noise on Output
This problem revolves around Pro Tools suddenly, and randomly glitching out and making the output sound incredibly thin, distorted with high pitched noise. To describe the sound further, it's a cross between a bit-crushed and ring modulated effect over the whole mix, but doesn't sound as cool as what I'm describing
I've tried searching for this issue online, but haven't had any luck. For the record, I'm 99% positive it has nothing to do with the standard gain staging mistakes within pro tools. It's completely independent to any of these sounds.
I ran into this problem again last night when listening back to a session through my interface. I had not seen it since I first encountered it using pro tools stand alone on my macbook pro, but didn't think much about solving it since I hardly ever use pro tools without my interface. Now that it is happening through my interface i desperately need to solve this.
It's a major show stopper. I cannot predict when it happens, and the only way to reset the sound is to go back into the playback engine and re-select my metric halo as the output device...and then it happens a few minutes later. I believe I have had this issue on all revisions of PT10, as it initially happened on my laptop (without interface) when i was running 10.0.1, last night I tried 10.1.2 and 10.1.3. I've just done a FRESH reinstall of my whole OS, and I'm getting the issue both on 10.1.3, and then 10.0.0 when i resorted back to that.
I can rule out these factors (or so I believe):
1. Not a plugin issue. When i did the fresh OS install, I opened the session before installing any plugins and had the problem.
2. Interface - doesn't seem to be my interface as last night i was able to recreate the problem when playing the session through the OSX aggregate device setup. Not to mention, this is how I first encountered the problem a few weeks ago.
3. I thought sample rate might be an issue as at the moment it is only happening with a session at 96kHz. HOWEVER, the session I made when I first ran into this noise was at 44.1...Although it's strange that I am not getting it at the moment with sessions at lower sample rates.
4. It happens on all outputs (cans, monitors, laptop speakers), so none of these are the cause.
5. Buffer size - happens even at the largest settings
Has anyone ever seen (heard) this issue before???
Some info:
Macbook Pro 2GHz Core i7, 8 GB ram
OSX Lion 10.7.3
Pro Tools 10.0.0 at the moment, about to try 10.0.1
Glyph GPT50 External FW800 drive
Metric Halo 2882
Old 04-29-2012, 11:09 PM
Default Re: Pro Tools 10 Distorted/glitchy/High Pitched noise on Output
I'm at a bit of a loss. I just had the issue when listening to iTunes, Pro tools not running.
Could be anything now I guess...
Mac Pro 6,1 6 Core Xeon
OSX 10.10.5
Pro Tools 12.3.1
Metric Halo ULN8 & 2882
Old 04-30-2012, 05:30 AM
feliponk's Avatar
feliponk feliponk is offline
Originally Posted by zygmunt View Post
Some info:
OSX Lion 10.7.3
Metric Halo 2882
Please update to 10.1.2, 10.7.3 is not supported with your 10.0.0
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Open Core Mac Pro OSX Ventura | ProTools HD 2023.x | Merging HAPI ADA8 | UAD Quad PCIe | Kali IN-8 | Presonus Temblor 10 | Softube, SSL, Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
Old 04-30-2012, 06:06 AM
Originally Posted by StewartFang View Post
yes...it's whatever is driving your speakers.
As in my interface? I don't think that is the sole problem, because it has happened coming out of my laptop speakers. I thought it was a clocking issue on my interface, but that doesn't explain why it sometimes happens when it is disconnected.
OSX 10.10.5
Pro Tools 12.3.1
Old 04-30-2012, 05:37 PM
C C is offline
I'm going to take a swing at you using an aggregate device for output?
Haven't managed to nail down the exact environment that causes me guaranteed problems but I have seen using Aggregate devices as a fairly consistent problem area. Could you try just outputting directly from the metric halo under iTunes and then under Pro Tools and see if the issue persists?
Thanks,
Ceri
Ceri Thomas
Personal Site
Mix Tech/Assistant Sound Editor
Old 05-04-2012, 06:46 PM
Thanks,
Ceri
Sorry for my late response. I am actually using the metric halo as the output device already. In my first post I state that I have had the issue on all versions of PT10. After wiping my OS, I'm back on 10.1.2, with OSX 10.7.3. I haven't had the issue with any other session (in 44.1), so I assume it is a clocking issue somewhere with 96k sessions. I have figured out it must be a metric halo issue then, since the problem pops up in itunes after running that 96k session. Once I have opened up a 44.1 session again everything is fine.
All of this does not explain how I had the problem a couple of times without any audio interface hooked up, but as you say Ceri, I also think that it is something deep in the aggregate device support etc. So, I think there are two different causes for this problem, in different situations.
OSX 10.10.5
Pro Tools 12.3.1
Old 08-21-2013, 03:04 PM
Tom Hansen Tom Hansen is offline
Ive got just the same problem you got, I just upgraded to an iMac and a new interface. Been dealing with this problem way to long with no luck. Have you figured out what to do with the high pitched noise? Next time it occurs I'm going to tape it on my phone and send it to sweatwater where i bought PT10, since its clearly a software issue.
Old 08-22-2013, 12:29 AM
I never figured it out, it just disappeared with various software upgrades etc, of which there have been many since this last happened. Sorry I can't help, never worked out what it was!
OSX 10.10.5
Pro Tools 12.3.1
Old 07-26-2015, 09:31 AM
OctopusOnFire OctopusOnFire is offline
Sorry to hijack this thread, but I'm suffering from the same problem, just as you described it. Seems somehow randomly originated, I can't figure out what's the specific cause. It usually gets solved either at the playback engine options or directly restarting pro tools. It's quite annoying, and it seems there's no explanation for it anywhere. I'm wondering if anyone around here has figured this out during the last couple years.
Thanks in advance!
Old 07-27-2015, 09:15 AM
john1192 john1192 is offline
Thanks in advance!
.. if you put in some system info it will help people here to help you ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Pro Tools LE + Bose Speakers > high pitched noise Problem sandmansndr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-10-2012 08:08 AM
high-pitched noise from psu dave192 Pro Tools M-Powered (Win) 1 09-11-2010 04:43 PM
High-Pitched Noise when in PT EnxStudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 10-02-2008 07:20 AM
High-pitched noise when Pro Tools runs Andy Carpenter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-17-2006 12:14 AM
High Pitched noise when opening pro tools LE 7 negativethree 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-26-2006 01:08 PM
