  #151
Old 01-02-2014, 08:20 PM
Fir3bird Fir3bird is offline
Default Re: Roland Octa-Capture crashes (PT 11 - Win 7 /64-bit )
Originally Posted by fiddlecat View Post
Sure, Avid was a bit stingy in keeping us informed about progress towards a fix (and that is my biggest complaint) but they did eventually acknowledged the issue and dealt with it.
Actually, this is what bothered me the most. Not having a proper answer a single time was really pissing me off.
Bugs happens. Not the first time I had to call à company for support but it's the first time I've found myself treated with such disregard. I know this is not an official way to get support from avid staff, but what have we left when companies are blaming each other for a bug.
You can notice than 11.1 is out and no word about that bug. As if it concerned only 2 folks on earth.
In my mind, when you buy a software you also buy the support for it.
Fir3bird
PT 10 & 11 / Octa-Capture
Vaio Z (Win7 64bits)
Full details on my profile...
  #152
Old 01-02-2014, 10:29 PM
JCBigler's Avatar
JCBigler JCBigler is offline
In some areas of the computer software community, this is the ONLY thing that you pay for when you "buy software".
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB
2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio
Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
  #153
Old 01-03-2014, 06:46 AM
chiv33s chiv33s is offline
Just an update from the recording point of view of the new update, it seems to work perfectly, not had any issues at all with it at the moment. I have noticed now that when PT11 crashes (in any way) there is a box that appears where you can send the crash report straight to Avid, which I think is a bit of a step forward, but I certainly agree with the terrible customer support and leaving us all in the dark for a while!
  #154
Old 02-02-2014, 04:01 PM
boller boller is offline
I've been using Octa Capture on PT 11.1.
It does work but only on one buffer size.
Not sure if I should do the PT 11.1.2 update or not...
  #155
Old 02-12-2014, 03:47 AM
yeahimsteve yeahimsteve is offline
I can't believe you guys even got it to work in PT10. I get the "hardware not found or is in use" error with the Duo-Capture EX in PT10.
Although, Roland is not the only company to have this happen to me. I had a Focusrite Scarlett 2i2 that did the exact same thing (gave me the error about hardware not found or is already in use) and I returned it because of that.
Funny how all these devices' ASIO drivers work perfectly in Cubase. So now whenever I need to do anything of substance, I just use Cubase.
  #156
Old 02-12-2014, 03:39 PM
fiddlecat's Avatar
fiddlecat fiddlecat is offline
Never had any problem with PT 10. Worked perfectly without a hitch.
It was PT 11 that initially caused problems and now it is mostly fixed with version 11.1. I can record, edit, mix, etc. just fine. It's only when changing sample rate do I still run into problems. I need to re-start PT with the Octa-Capture already set to the appropriate rate for things to run smoothly. Other than that, I'm OK...
Pro Tools 2023.6 & 10.3.0
Windows 11 Professional / 64-bit
Roland Octa-Capture
  #157
Old 07-02-2014, 10:26 PM
uQbar uQbar is offline
Any hints on how you got it to work? What settings are you using? Under 11.2 I get out of CPU the second I hit play even on a totally empty project (with zero CPU use shown on the PT meters or OS meters - I'm on Window 7)
  #158
Old 07-04-2014, 07:47 PM
I put in a support ticket with Roland and got a reply back - after I already got my rig up and working. For what it's worth Roland said the issue should be fixed with the recent 11.2 upgrade - there was an issue and it's supposedly now fixed in PT11.2.
My issue was either drivers or buffer size - I messed with both at the same time and so I can't say which fixed things.
Pro Tools 9, Roland Octa Capture - iMac, No Sound Playback Mike1005 macOS 2 12-27-2013 02:59 PM
Roland Octa-Capture fiddlecat Windows 24 06-30-2013 06:35 AM
FS: Roland Octa-Capture - Like New agershon Buy & Sell 1 12-26-2012 07:51 AM
11R and Roland Octa Capture Marshall881 Eleven Rack 6 03-09-2012 08:37 PM
Roland Octa Capture mikemolloy1971 Windows 1 09-22-2011 07:23 AM
