#151
Re: Roland Octa-Capture crashes (PT 11 - Win 7 /64-bit )
Bugs happens. Not the first time I had to call à company for support but it's the first time I've found myself treated with such disregard. I know this is not an official way to get support from avid staff, but what have we left when companies are blaming each other for a bug. You can notice than 11.1 is out and no word about that bug. As if it concerned only 2 folks on earth. In my mind, when you buy a software you also buy the support for it.
Fir3bird ----- PT 10 & 11 / Octa-Capture Vaio Z (Win7 64bits) Full details on my profile... |
#152
In some areas of the computer software community, this is the ONLY thing that you pay for when you "buy software".
Justice C. Bigler www.justicebigler.com Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB 2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre Road/hotel: Roland OctaCaputre / Apogee One |
#153
Just an update from the recording point of view of the new update, it seems to work perfectly, not had any issues at all with it at the moment. I have noticed now that when PT11 crashes (in any way) there is a box that appears where you can send the crash report straight to Avid, which I think is a bit of a step forward, but I certainly agree with the terrible customer support and leaving us all in the dark for a while!
#154
I've been using Octa Capture on PT 11.1.
It does work but only on one buffer size. Not sure if I should do the PT 11.1.2 update or not... |
#155
I can't believe you guys even got it to work in PT10. I get the "hardware not found or is in use" error with the Duo-Capture EX in PT10.
Although, Roland is not the only company to have this happen to me. I had a Focusrite Scarlett 2i2 that did the exact same thing (gave me the error about hardware not found or is already in use) and I returned it because of that. Funny how all these devices' ASIO drivers work perfectly in Cubase. So now whenever I need to do anything of substance, I just use Cubase. |
#156
Never had any problem with PT 10. Worked perfectly without a hitch.
It was PT 11 that initially caused problems and now it is mostly fixed with version 11.1. I can record, edit, mix, etc. just fine. It's only when changing sample rate do I still run into problems. I need to re-start PT with the Octa-Capture already set to the appropriate rate for things to run smoothly. Other than that, I'm OK...
Pro Tools 2023.6 & 10.3.0 Windows 11 Professional / 64-bit Roland Octa-Capture |
#157
Any hints on how you got it to work? What settings are you using? Under 11.2 I get out of CPU the second I hit play even on a totally empty project (with zero CPU use shown on the PT meters or OS meters - I'm on Window 7)
#158
I put in a support ticket with Roland and got a reply back - after I already got my rig up and working. For what it's worth Roland said the issue should be fixed with the recent 11.2 upgrade - there was an issue and it's supposedly now fixed in PT11.2.
My issue was either drivers or buffer size - I messed with both at the same time and so I can't say which fixed things. |
Pro Tools 9, Roland Octa Capture - iMac, No Sound Playback | Mike1005 | macOS | 2 | 12-27-2013 02:59 PM |
Roland Octa-Capture | fiddlecat | Windows | 24 | 06-30-2013 06:35 AM |
FS: Roland Octa-Capture - Like New | agershon | Buy & Sell | 1 | 12-26-2012 07:51 AM |
11R and Roland Octa Capture | Marshall881 | Eleven Rack | 6 | 03-09-2012 08:37 PM |
Roland Octa Capture | mikemolloy1971 | Windows | 1 | 09-22-2011 07:23 AM |
