Old 04-09-2004, 06:55 PM
DOUBLE EDGE DOUBLE EDGE is offline
Default Just Got Cubase SX and need help
do you guys know how to set it up to run with my digi001 i/o.. i go into device setup and only my built in audio controller shows up in the drop down menu. Im running osx10.2.8 and the audio/midi setup shows digi001/hw as the input and output.. please tell me where i can find a asio driver for this problem or another solution.. thanks...
Mac Pro 2.66 - PT 7.3.1 cs2 -
Old 04-09-2004, 08:03 PM
mersisblue mersisblue is offline
Default Re: Just Got Cubase SX and need help
I have cubase SL 2.0 and what I had to do was open up applications find pro tools folder in there you will find
CORE AUDIO launch it and add the cubase application
then in cubase you should be able to select the 001 as an audio card in device setup
Old 04-10-2004, 02:57 AM
Phydaux Phydaux is offline
Good luck, I can't get SX to even launch with my 002. Cubase say they don't support it.
Let me know if you can sort it out.
Old 04-10-2004, 10:13 AM
superlovemark superlovemark is offline
Works for me with SX 1.053 and CoreAudio on a 002r. Only problem I have is with serious MIDI latency.
iMac G5 1.8/ 10.3.5 / 768 ram
Digi 002r / PT LE 6.4
Logic Pro 7
2 OWC 80G firewire drives
many nice noise makers
Old 04-11-2004, 06:47 PM
THANX FOR THE ADVICE.. i got it working. but my only prob is the latency.. i have it minimized to 2 milliseconds and its still killing me.. can you recommend something?
Old 04-11-2004, 07:50 PM
I use a console so I dont have that problem
sorry
took awhile to reply huh? go , on vacation ?
Cubase SX3 abd Cubase 4 LE STILL no MIDI! Shiver1 MIDI 2 12-02-2008 10:30 AM
Cubase to PT MusoPro Pro Tools TDM Systems (Mac) 9 09-16-2005 06:21 AM
PT 5.3 and Cubase SX Ben_jamin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-13-2002 02:52 AM
Has anyone taken a look at cubase SX? bascani 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 04-20-2002 03:17 PM
Cubase with Digi001, where to set latency on Cubase Eiko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-17-2000 08:28 AM
