where did my post go? trouble with click in LE 6.1
I'm confused, I posted at 2:30 central today with a question regarding why the click plugin will not work with my 002-6.1 LE ProTools. Came home expecting to find a myriad of helpful answers to my query only to find my post had been deleted. Wow!-I'll ask again;
After a search of the DUC I found no other posts regarding this issue so I thought I'd ask the group. Why will the click not work? I am trying to use it in a small session (20 tracks) mostly digirack gate and eq plugs with Reason instantiated on a track. Reason's click works in this case but Protools click plug will not. Any answers will be appreciated. system dual 1.4 with 1 gig ram os 10.2.5 protools le 6.1 |
Re: where did my post go? trouble with click in LE 6.1
Your other thread is about 12 down from this one, it wasn't deleted. you have one reply from another user who had a similar problem but no fix. I haven't had this problem since I don't use the click plug-in, but I'll try to help.
What kind of track are you using the click plug-in on? Aux track or Audio track? You should be using an Aux track. Also, low-latency monitoring may affect the click plug-in, but I don't know for sure, so check that out. Have you tried removing the plug-in and re-insterting it? |
Thanks for the reply, both problems solved, both caused by operator error.
PRE POST AUX sends trouble | KeithFinch | VENUE Live Sound Systems | 6 | 03-13-2012 12:56 PM |
Click track trouble | blackroom321 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-12-2008 11:08 AM |
click track trouble plus two other questions | fall_brook | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-14-2003 06:46 AM |
Click Track ... DIgi, where is my post? HELP! | john1192 | Pro Tools TDM Systems (Mac) | 0 | 09-13-2003 11:11 AM |
CLICK TROUBLE! | jam | Pro Tools TDM Systems (Mac) | 1 | 02-27-2000 07:30 PM |
