Old 07-07-2001, 12:01 AM
paulpatras paulpatras is offline
Default Is simultaneous use of sp/dif and lightpipe possible?
Hello all and Happy Friday!
I have recently purchased a digital pre-amp (Presonus Digimax) and am using the adat lightpipe to optical into my 001 setup. I would like to use an outboard effects unit (Lexicon MPX1) simultaneously with it. The MPX1 is sp/dif'd in/out of my 001.
I record optically using the Digimax, create an auxilliary stereo track, bus the original track to it, insert sp/difs on aux track and I get an annoying high pitch tone that starts soft and quickly reaches an unbearable level.
Is anyone using both the optical and sp/dif at the same time successfully. If so, what is your hardware set up in LE, what are your track configs, etc.
Any thoughts, suggestions, comments?
I greatly appreciate your time and consideration.
PaulP
My set up:
Intel Pentium III 750mHz Processor
Intel D815EEA Motherboard
ATI 128 16MB AGP DDR Video Card
ATA-100 Controller built-in
256MB 133mHz SDRAM
1.44 3.5" Floppy Drive
40GB Ultra ATA-100 7200rpm Hard Drive
60GB Ultra ATA-100 7200rpm Hard Drive
Mid-Tower Chassis w/Secondary Fan
Windows 98 (Second Edition)
Old 07-07-2001, 12:43 AM
ReniuR ReniuR is offline
Default Re: Is simultaneous use of sp/dif and lightpipe possible?
You have a similar setup to mine. To answer your question, you should be able to use all inputs of the digi at the same time.
-ReniuR
www.disposableproductions.com
What does simultaneous in/out mean? Pro Tools Noob Sm. Caulk Tips & Tricks 9 03-27-2013 08:07 PM
PT 9 and PT 10 simultaneous? Shatzer Pro Tools 10 2 10-20-2011 10:11 PM
How many simultaneous record ins Alwyn Walker Eleven Rack 11 09-21-2011 06:36 PM
16 simultaneous I/O on 192 greglawrence Tips & Tricks 8 02-08-2007 06:05 PM
Is simultaneous usage of sp/dif and lightpipe possible? paulpatras General Discussion 4 04-29-2003 09:52 AM
