Old 12-30-2010, 08:15 PM
PostHuman PostHuman is offline
Default Just got my Omni. Some questions...
The main output from my Omni TRS OUT 1 and 2 are going into my monitor speakers. Do I set the Omni OUTLVL to Speaker (+10dbu) or Line(+24dbu)?
What if I send the Omni to my Presonus Central Station to be able to switch through 3 different pairs of speakers. Digital out or TRS 1&2? which is better? Will the Presonus Central Station degrade sound quality at all? Should I just ditch the Presonus Central Station and just take the time to plug in each set separately when needed?
Thx in advance.
MacPro 2x3GHz Quad-Core Intel Xeon, SL 10.7.2, PT HD 10, Avid HD I/O & PRE, M-Audio Axiom Pro 49, MOTU MIDi Express 128, & many synths.
Old 12-30-2010, 08:46 PM
nst7 nst7 is offline
Default Re: Just got my Omni. Some questions...
You won't want to use the digital in of the Central Station, because then you'll be using the Central Station's d/a converter, which is not nearly as good as the Omni's. As far as plugging into just the Central Station analog in's, you might just try it and do a comparison.
Old 02-20-2011, 11:03 PM
chrisdee's Avatar
chrisdee chrisdee is offline
Doesn't the Omni have 8 outputs ?
You could hook up to 4 monitor pairs directly instead of potencially degrading the quality through your central station ?
Old 02-21-2011, 04:14 AM
Bill Denton Bill Denton is offline
One question that is going to come up is whether you are using active or powered monitors.
Also, the Omni has a Main/Alt monitor switch on the front panel. Could you use this for the two sets of monitors you use most, and plug in the third set only when needed?
I found this really confusing when I first read this in the Omni manual (Disclosure: I really don't know very much about this stuff; hopefully someone who does will chime in with an explanation).
I was under the impression that active monitors were designed to accept a line level signal, but the Omni treats the monitor signal and the line level signal as two different things. Why, I don't know; hopefully we'll hear from somebody who does...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 02-21-2011, 07:30 AM
From page 26 of the manual:
"Output Level
"Select the appropriate Output Level for each of
the eight analog output channels. HD OMNI
provides two options for output levels:
"Speaker (+10 dBu) Select this option for output
channels connected directly to powered monitors.
"Line (+24 dBu) Select this option for output
channels connected to line-level devices (such
as an analog mixing console)."
So assuming you have powered monitors, you would set it for speaker. As Bill mentioned, I don't know why that would be any different from line level. Kind of strange.
Old 02-21-2011, 11:26 AM
sndgeek sndgeek is offline
I think this is the way you differentiate between "consumer" line level and "professional" line level. Most consumer gear runs 14dB quieter than pro gear (a la mixing boards, I/O's etc). Used to have to run an Aphex line converter to get my consumer gear (DVD player, iPod etc) to get proper level into ProTools.
Chaos is a name for any order that produces confusion in our mind. --George Santayana
Old 02-21-2011, 01:57 PM
That's the problem...in the US "pro" line level is +4 dBu, where consumer line level is -10 dBv.
Neither of these match up to what is shown in the Omni manual.
Further, in the specs for the Focal CMS 50 5" Nearfield Reference Monitor (just one I grabbed out of the air), it says "Adjustable sensitivity: +4dBu / 0 / -10dBV", which corresponds to the pro and consumer line levels (plus 0, just to confuse things).
And further still, just to confuse things even more, on the HD I/O, it lists the analog line outputs as +4 dBu.
Kinda makes me wonder if the numbers in the Omni manuals might be typos. Maybe Avid can chime in and help us out...
X
Bill in Pittsburgh
Last edited by Bill Denton; 02-21-2011 at 01:58 PM. Reason: Correcting incorrect information
Old 02-23-2011, 08:13 AM
Avid, could you give us a clarification on the levels?
X
Bill in Pittsburgh
Old 03-04-2023, 07:33 AM
Siddhant Bhatia Siddhant Bhatia is offline
Bump!
Facing a very similar problem. Would love to know more about these levels. Avid?
Old 06-03-2023, 02:06 PM
Sugarnutz Sugarnutz is offline
If you set the Omni to +24 you will lose the monitor level control on the front panel as they become fixed outputs instead of variable.
Gigabyte z390 Designare
I9 990K 4.7 GHz
64 Gb of DDR4 3200
Gigabyte RX580 8 Gb
Win 10 Pro
15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM
512 Gb Flash Drive - OS X 10.14.6
Omni vs HD 8x8x8 io and Omni Pre's Southsidemusic Pro Tools HDX & HD Native Systems (Mac) 13 03-27-2013 01:00 AM
OMNI Fried? Calling Omni Members - Check High Samplerates KingFish Pro Tools TDM Systems (Mac) 3 11-03-2011 09:19 PM
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan FRaNCo MuSiC Pro Tools HDX & HD Native Systems (Win) 0 09-25-2011 05:42 AM
2 questions ...Hd omni question, native, imac doyoung123 Pro Tools HDX & HD Native Systems (Mac) 8 06-12-2011 05:31 PM
HD Omni Kobra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 40 09-14-2010 06:22 AM
